New Red Llama layout and transfer
Started by MartyB, July 06, 2005, 07:35:53 PM
nelson
Thanks Marty, 4049 will be in my next parts order :), if it doesnt come in the Futurlec Ic pack I have coming..... Nice Layout.
My project site
Winner of Mar 2009 FX-X
bluesdevil
Great job!! Just wondering, how does it compare to the Hot Harmonics?
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
mrsage
nelson
My project site
MartyMart
MartyB - nice one ! :D
PS: just had a scoot round your site ( cool ) and on the "Hot Harmonics"
text, I think you meant to say "+9 volts to pin 1 and ground pin 8" - NOT
the other way around  !!  :D
Cheers,
Marty.
MartyB
MartyMart,  Thanks for the encouragement.  I think the schematic is ok.  From the pinouts I've seen pin 1 is the topmost pin on the left looking down on the CD4049UBE top, pin 8 is the bottom-most.  The schematic and descriptions diagram was copied without changes from Frank Clarke's site.
On a side-note, everyone I know in the US feels horrible about what happened today in England, me included.  I wish the families well.  Is it too simple? Violence will not foster a desire for peace, nor kindness in its victims.
MartyB :cry:
Paul Marossy
Wow, that's a simple circuit. Isn't it recommended to ground all of the unused pins, though?
MartyB
You have to ground the unused inverter inputs to prevent an unstable situation as described by Peter Snowberg.  The input pins are 3,5,8,9,11, and 14.  All of those are accounted for in the layout.
HTH
MartyB
moosapotamus
... or use the extra inverters to build this, and include in the same box.
http://www.runoffgroove.com/mreq.html
... maybe with a 4-pole rotary switch to select for pre, post, or no EQ.
... oh, and throw in a parallel buffer for a clean blend control and use it for bass, too. 8)
~ Charlie
moosapotamus.net
soggybag
I had been thinking you could take the extra two buffers left over from Mr EQ and tack them on the end like the Three Legged Dog. And have a tube sound over drive with eq options. And as a bonus have no wasted inverters.
Paul Marossy
QuoteYou have to ground the unused inverter inputs to prevent an unstable situation as described by Peter Snowberg. The input pins are 3,5,8,9,11, and 14. All of those are accounted for in the layout.
HTH
MartyB
Oh, I see. It's been a while...
QuoteI had been thinking you could take the extra two buffers left over from Mr EQ and tack them on the end like the Three Legged Dog. And have a tube sound over drive with eq options. And as a bonus have no wasted inverters.
Interesting idea. Has anyone ever tried this?
B Tremblay
Quote from: Paul Marossy
RickL did: http://diystompboxes.com/sboxforum/viewtopic.php?t=33874
B Tremblay
runoffgroove.com
soggybag
Here's what I drew yesterday. This probably needs some changes. I put the gain and EQ before the last two inverters.
Paul Marossy
One question on the layout: that diode, is it just a 1N4148 type?
MartyB
Paul Marossy
I used a 1N914. It seems to work fine. I made the the PCB ans populated last night/this morning. Interesting circuit, kind of unique sounding. I like it.  8)
EDIT: Thanks for the PCB layout!
Paul Marossy
I'll have it boxed up tomorrow sometime. I'll post a picture of it.
