Quick circuit help.
Started by georges, July 15, 2005, 05:43:04 AM
georges
Hey there, I'm new here.
I'm doing an MXR distortion + for my tech GCSE and have been told that since you don't know if it will sound good if you design the circuit yourself, I am allowed to use a circuit already made, if I make a modification.
I am trying to combine http://www.tonepad.com/getFile.asp?id=4 (The MXR version on that) with offboard wiring style 5(removing the power supply jack) from http://www.tonepad.com/getFile.asp?id=76
I came up with
If this is correct I'll redo the schematic properly for my project. If not could someone point me in the right direction?
Cheers, George.
idiot savant
georges
Quote from: idiot savantI didn't look at the pic, but the BEST offboard wiring schemes can be had at:
http://www.generalguitargadgets.com/index.php?option=content&task=view&id=172&Itemid=200
Ok, cheers. I just wanted to know if the links were right from the offboard to the mxr circuit though :)
Offboard wiring is 'generic'. There are different ways to do it. AFAIK they all work.
 I prefer DPDT or 3PDT [for LED indicator switching], wired true bypass.
georges
Quote from: petemooreOffboard wiring is 'generic'. There are different ways to do it. AFAIK they all work.
Ah.. seems like everyone misunderstood. I just wanted people to check that I wired them together right before I go make something wrong. I was kinda guessing where to link the wires.
EDIT: also it uses a 3PDT switch with LED
littlegreiger
Yours looks good to me. Go for it and have fun.
georges
Quote from: littlegreigerYours looks good to me. Go for it and have fun.
Cheers. Will do. :D  Can't wait till it's finished. I reckon I'm gonna get a couple of sockets and a hellova lot of a diodes and LEDs and just try it all even though I know I'll settle on LEDs regardless of sound :P  8)  :roll:
aron
Check this out from the beginner forum (you should check out everything in there)
http://www.diystompboxes.com/sboxforum/viewtopic.php?t=970
littlegreiger
What value pots are you using? I just ask this question because when I was building mine the good people here suggested that I use a 100k log pot for the volume control and a 500k reverse log pot for the gain. I found these values work quite well. Best of luck with your build.
georges
Quote from: littlegreigerWhat value pots are you using? I just ask this question because when I was building mine the good people here suggested that I use a 100k log pot for the volume control and a 500k reverse log pot for the gain. I found these values work quite well. Best of luck with your build.
I'll buy a few different ones I think and include those ones. Cheers!
