Parts list for the Shaka Tube?
Started by bass_econo, July 19, 2005, 10:10:26 AM
bass_econo
I've searched and read all the posts on the Shaka Tube and listened to the clips from various people.  I want to build one and I have some extra tubes at home to play with.  The problem is that I'm having a hard time compiling a parts list for it.  Can anyone help me on this?
Also I think that some use a transformer and other do not.  What is the difference?
Paul Marossy
I am not aware of a parts list for the Shaka Tube. I made up my own parts list at the time of construction (no I don't have it anymore). On the transformer, one is definitely required - a 120VAC/12.6VAC 800mA wall wart is perfect in my experience. DO NOT try to use a DC wall wart, it will not work.
transient
Ok, i'll give it a shot:
resistors:
10 ohm (this should be 1W, while the other resistors can be 1/4W)
220 ohm
470 ohm
1 K x3
10 K x4
47 K x2
470 K
capacitors:
250 pf
0.01 uf x4
0.1 uf
2.2 uf
22 uf x2
470 uf x4
TL072 IC
1N4001 diode x2
12AX7 (ECC83) tube
100 K A pot - drive
100 K B pot - tone
10 K A pot - volume
10 K trimpot - bias
12 V - AC adaptor
9-pin tube socket
8-pin socket for IC (optional)
mono jack x2
enclosure
emre
Paul Marossy
Quote8-pin socket for IC (optional)
Definitely recommended!  :wink:
puretube
a thick wire (hi-oxygen copper with silver surface), for the ground-busss...
MartyMart
Quote from: puretubea thick wire (hi-oxygen copper with silver surface), for the ground-busss...
:lol:  :lol:
Marty.
transient
Forgot to add these:
3PDT switch (gold-plated for the mojo factor)
LED (you might want to use an actual tube instead of a LED, again for the mojo factor)
:D
e
Paul Marossy
Quoteyou might want to use an actual tube instead of a LED, again for the mojo factor
Make sure you add 150mA to your transformer specs if you do this.  :wink:
Paul Marossy
bass_econo
Boy this sure got out of hand real quick. Thanks by the way.
Could I just paint a tube blue?  :D  :D  :D
Paul Marossy
QuoteCould I just paint a tube blue?
That would make it more bluesy!  :wink:  :lol:
