Ring Stinger Photos
Started by soundcollage, July 23, 2005, 06:45:13 AM
soundcollage
Yes, here it is the Lovetone Ringstinger. There are a couple more photos at photobucket and i can take more if meed be. Let me know if you need measurements.
[/url]
james
KarbonHed
Wow, that will take some decoding  :shock:
But thanks, I always wondered what's under the hood of one of them.
markusw
Thanks a lot!!!!  :D
Tough stuff for reverse engineering (at least for me). Are the transistors still labelled?
Markus
PS: Some more Qs if you don't mid:
Are the pots labelled? What values are the caps? Are there specs on the two transformers? Could you probably take a closer picture of the small PCB?
Again, thanks a lot!!! I was waiting for this oportunity for quite some time.  :D
corbs
i'm supprised they don't cover that ldr/led coupling in anything.
soundcollage
All transistors marked bc549 028:c.
Pots from left to right overhead-- depth: 91a1ab24b20-100k(0032x), rate:91a1ab24b20-100k(0032x), freq: 91a1ab24b20-100k(0032x), drive: 91a1ab24d20-100k(0024x), timbre: 91a1ab24b20 100k(0032x), blend: 91a1ab24b10-1k(0032x).
I'll post the cap values when I get off work later.
james
puretube
soundcollage
I know my photographic skills are lacking, you don't need to rub it in. :D
james
Bill Bergman
Excellent bee picture Puretube.
Connoisseur of Distortion
you can see the individual hairs on that bee...  :)
pity all the ICs have been scrubbed clean of writing... but i suppose a schemo will show which chips would make the most sense.
any brave souls for tracing it?
soundcollage
Here are the cap values
photobucket butchered this-- the little blue caps are marked from top to bottom:
u1k63
u1k63
6n8k63
1n5k63
3n3k63
u47k63
6n8k63
a better picture of the sub board with the transformers and diodes will prob come in the next day
james
soundcollage
The transformers are stamped at the top LT-44. Looks like they tried to grind off the numbers but the stamp was too deep. These seem  to be balancing/matching transformers with a 20k primary and a 1k secondary.
By the way all u's should be mu's but I dont know how to make that character appear.
james
puretube
try: "Alt" & "m": µ   (the right-side "Alt" - dunno how it`s called in english - in german it`s: "Alt Gr")
soundcollage
Thanks it works µµµµµµµµ. Excellent photo, by the way.
james
Paul Marossy
Wow, that's a busy board. What does it do anyhow? Is it some kind of octave/distortion pedal?
puretube
Quote from: soundcollageThanks it works µµµµµµµµ. Excellent photo, by the way.
now you can try "Alt Gr" & "e", to get a â,¬ (Euro)...  :)
btw: the pic was not intended as a comment on photographic- or camera-quality at all !
Just remembered it, when I read the topic: Stinger & Photos
:D
ExpAnonColin
More pics FWIW (someone sent me these asking for help reverse engineering it, said he drew a schem out, and then stopped answering emails).  I think we decided all the larger chips were quad OAs.
http://www.experimentalistsanonymous.com/other/Ring%20Stinger%20Innards.JPG
http://www.experimentalistsanonymous.com/other/ringinside3.jpg
http://www.experimentalistsanonymous.com/other/ringinside4.jpg
-Colin
Paul Marossy
QuoteI think we decided all the larger chips were quad OAs.
That would be my guess, not knowing anything about the circuit. I wonder if this is something like the Anderton "Quadrafuzz"?
the ring stinger is a ring modulator, i think. they have sound samples on the lovetone site... i really want their Flange With No Name  :)
soggybag
I like that it uses the transformers and diode ring method. I bet they have to be matched?
Does anyone know how to match transformers and diodes?
There was a guy on ebay selling a ring mod kit with PCB, jacks and tranformers and matched diodes. Someone on the list got one of these but I haven't heard any more about it.
ExpAnonColin
Quote from: Paul Marossy
I'm afraid not... quadrafuzz is a multiband distortion and the ring stinger is a diode ring modulator, creating distortion while 4 quadrant multiplying.  Both are snazzy though :)
-Colin
