insanity box wiring.. help plz!
Started by chaney, August 01, 2005, 12:54:52 AM
chaney
Hello!
I'm build now is insanity box. http://diystompboxes.com/pedals/insanity.GIF
it asks for advice with a picture.
http://blog.empas.com/expand.html?url=/mickeyh/20849524_570x845.gif
Does a wiring picture no problem?
insanity box made now. Mmm... Some Problem!
Bypass clean sound OK! but DPDT sw on.. no sound.
please help me
RandomRedLetters
Double check and make sure the input and output on the board are wired to the right connectors on your switch, if they're flipped (input wire going to output jack, etc) you wont get any sound.
Slash
There is a problem becouse the RC4558 and Tl071 are not pin compatible,
you can try to wire it right or just replace it with an tl071,tl081
if you're not sure about the pin connections get the datasheets from
http://www.datasheetcatalog.com
Jaicen_solo
Also, the MPF102's have a different Pinout than J201's. Make sure the legs are in the correct places.
chaney
thanks to Slash. ^^
replace part MPF102 to 2N5457
and 4558 to TL071!  great sound!   :)
aron
