using trannies as diodes?
Started by tungngruv, August 08, 2005, 01:36:09 AM
tungngruv
I remember reading here about using transistors as diodes. After searching through this forum and the FAQ's, I still can't find the post. Can someone please point me in the right direction? Thanks in advance.
RandomRedLetters
the collector-base junction is a very low leakage diode. Test continuity because I forget which is the anode and which is the cathode. The emitter can be left unattached.
aron
Sir H C
Also there is what is called "diode connected transistors" where you tie the collector to the base.  In this format you get a very sharp knee.  Sometimes they call this a "super diode" (at least in old ARRL books).
tungngruv
Thanks very much everyone!!!!!! That's where I saw it Aron :D So once I connect the base + emitter, how do I know which end is the cathode? Once again, thanks in advance!
Sir H C
Collector and base is the "super transistor" and the collector is the positive side, emitter negative (for an NPN device).  With the base tied to the emitter you get a low leakage diode (IIRC) and then the base/emitter is the positive and the collector is the negative.
Either way, the base, for an NPN, is the positive terminal of the diode.
DDD
I've tried trannies as diodes in the diode clipper with couple of "diodes" in both directions. So there were 2 transistors - 1 pnp and 1 npn.
The sound was sandy comparatively to 1n4148 and I didn't like it.
tungngruv
Thanks again everyone!!!!!!! Sir H C, That's what I needed to know. Thanks!
