Pedalboards.com-sized enclosure
Started by Primus, August 09, 2005, 12:04:18 AM
Primus
I need a narrow enclosure like the one used at pedal-racks (pedalboards.com) for a small tap delay, channel switching, sample reversing control pedal I am making. Anyone know where I can get something like this?
JP
Also, I am going to try his XLR cable power trick some time.
I suspect somewhere there is a factory crankin' out an extruded aluminum ships ladder step or similar metalwork that if tapped would make a nice resource for cutting off some for a long box top and 2 sides..
 I'm a little surprized that there isn't someone extruding aluminum sides and top lengths, cutting them and tacking in ends. I have a strong aluminum ONKYO reciever panel I put a S.Blend, BMP, Booster, 4 jacks and a wah in, still have room yet for more...it has stress 'T's running the length of the long sides to keep it from twisting.
 I framed it for 4 appealing sides and a bottom, and backed the tuner indicator window. It'd look really cool with Drum Covering on the top.
stumper1
It's not cheap but Mouser has Hammond boxes as small as 2"x2"x1.06" deep.  Part#546-1590LB - around $7.00.
Good Luck!! :wink:
DericĀ®
