StephenGiles
markm
Quote from: StephenGiles on November 13, 2006, 02:54:05 PM
Looks terrific!
That multi-effects thing is spectacular!
I'm impressed as all hell!  8)
Sweetalk
Really awesome... I want something just like that!!!
Congratulations
sfr
Jeez, I was about to start the final stages of my multi-fx thing, and now I want to start all over again!  That's looking real nice!
brad
Quote from: dano12 on November 13, 2006, 12:38:27 PM
Hey Brad, did you try different values for the decoupling caps? Also, did you keep the one meg pots between stages? Do you think a 12AJ6 could be used as a clipper? Yeah I know, questions questions :)
No, I kept the same coupling caps and pots for each stage because I'm lazy :D  Oh, and you can use the 12AJ6 as a clipper no problem.
"If You Can't Open It, You Don't Own It"
Auke Haarsma
that multi FX unit looks PRO! Awesome!
(makes me long back to my sold GNX4 ;) )
Dave_B
That's really something, Andre.  Did you bend the aluminum yourself?  It looks perfect.
Help build our Wiki!
Andre
Thanks Dave and all the rest.
It took some time to build but I'm very happy with the result.
Maybe it doesn't show well in the pictures but it is not aluminium but 2mm
stainless steel. Impossible to bend without the right machine, so this was the only thing
I have not done myself.
Now I need to build some flightcase around it.
André
$uperpuma
Well, I'd been threatening to do it since I accidentally over-etched that skull box... Its the Giger Gun, etched.  I was QUITE disappointed when Ibanez came out with the Giger line of guitars... as I've had this idea for quite some time, here it is.  The Theoplex Fuzz is basically an Octavia.. its not done but I was excited and wanted you guys to see it.
mikey
WARNING!  SEVERE PEDAL ENVY ALERT!
Quote from: Andre on November 13, 2006, 01:54:42 PM
My modular effects unit.
Not completely finished, but already working and worth to show I think.
Andre! Your multi-fx looks fantastic!
jrc4558
Andre! What a cool multiFX unit! Looks much better than mine...:)
Care to tell how you built the enclosure? ::)
Sweetalk
QuoteThanks Dave and all the rest.
André
Stainless Steel?... I thought that was aluminium... It has some kind of coat??
Andre
QuoteCare to tell how you built the enclosure?
I'm working on a webpage about this thing.
I will let you know when it is finished.
QuoteStainless Steel?... I thought that was aluminium... It has some kind of coat??
It has 3 layers of clearcoat, otherwise you will see every fingerprint on it, and for protection of the decals.
Sweetalk
Great!.... I'm Working on a proyect like that to have a case and plug the pedals that I want, I'm working in aluminium but I didn't find someone that blends it!  :icon_frown:
Here's another one of mine... An overdrive with extra gain, it's not a clon!!... It's a double opamp over,"TS-kind" but isn't a TS... The finish it's spray paint with clear satin coat and decal paper for the labelling.
I Finally changed the LED Bezel... I didn't like much that.
Andre
Look great Sweetalk
Very nice graphics too, but you're right about the LED bezel
Sweetalk
Thanks!!!!.... I put a White one, in page 35 of this topic are another ones of mine... Another thing that I regret (one of the reasons it's bad measurement) it's putting the 3 pots in line with that knobs... They're beatyfull but they're BIG... next time I'll make another distribution...
jrc4558
Quote from: Andre on November 15, 2006, 07:54:18 AM
WUNDERBAR!!! :)
Samy
Quote from: Sweetalk on November 15, 2006, 08:02:18 AM
Looks great !  :icon_wink:
The decal paper you used is the adhesive transparent paper ? It´s printed on Ink Jet or laser ? It looks really great !
Thanks.
Sweetalk
Quoteooks great !  icon_wink
Yes... it's adhesive transparent paper printed in inkjet, looks really great. Thanks!!!!
bent
#1379
Sweetalk , it's a very nice pedal, the graphic is perfect... :icon_eek: :icon_eek: :icon_eek:
where can we get this adhesive transparent paper ?
and did you have to change setting on your printer to match the color, since printer dont print white does the green was the same that appeared on your screen when you do it...?
bent
Long live the music.....
