@chris cheers for the pointers man, i'll have a look around.
@haddock..i'm surprised nobody asked about your pot leds?...looks good..
drilled through the shaft i presume..cool. :icon_cool:
@pigyboy...man they look slick... :icon_cool:
@guitarify...nice design dude...top tip..use nail polish on the big black areas before etching..to avoid those speckled bits... :icon_wink:
free electron
I've built a tube bass pre + VCA based compressor for my bass recently. The tube part is a typical fender clean channel (triode stage-EQ-triode stage) circuit using RFT ECC81. The compressor part is solid state, based on THAT4301 app.
Hand painted enclosure + decals.
ayayay!
NICE JOB FREE ELECTRON!  I love that!  Did you actually make that PCB too?  Either way, still great work.  Nice job on the tube vent drilling... just a great all around job.
I've never seen a DPDT thru-board wiring setup like that either, but I get it.  Very cool!
The people who work for a living are now outnumbered by those who vote for a living.
Almost embarrassed to show my stuff here nowadays, the bar is so high.....
free electron
#15404
Quote from: ayayay!
Thank you!
Yes, i've made it. Actually it's a kinda gorilla style pcb, a double sided mixture of thru-hole (high voltage tube part) and SMT (low voltage solid state) components, placed on both layers. This pedal is highly experimental, many things could be done in a simpler way, but i wanted to try some ICs in action, like the SSM2402 used to bypass the compressor part.
frequencycentral -->> Cool knobs! :)
Hides-His-Eyes
Rick; you don't need to feel sheepish. Some of these beautiful builds are of things you helped to design/designed, for a start!
And that's a very nice build in itself. Is that the power supply around the switch?
Quote from: Hides-His-Eyes on February 26, 2011, 12:27:46 PM
Thanks! Yup it's a voltage multipier. I originally designed the pedal to run on 12 volts, but 12 volts is such a hassle on a pedalboard, so I redesigned it to run on 9 volts with an in-built votage multiplier to get up to 18 volts. I used a version 1 PCB though, the new version 2 PCB has the voltage multiplier integrated onto the main PCB.
Haddock
#15407
Hi,
[/quote]
your wiring reminds me of super mario tubes!!!!hahhahah great!awesome etchings....what do you use for them?
[/quote]
thanx tasos , i use only waterslide decals....for me are tihs the best results.
Quote from: deadastronaut on February 26, 2011, 05:25:39 AM
Thanx deadastronaut, yes, i drilled through the shaft (2mm). There is a turitorial in the german forum and i have no troubels with this
system.
Greetings
Urs
100% agree...
@haddock..thought so..looks great........now where to get clear round knobs.... :icon_wink:
markeebee
Quote from: Perrow on February 25, 2011, 07:14:25 PM
I love the lateral thinking that goes into making alternatives to Hammond boxes. What is that, a hard drive enclosure?  I like the utilitarian look of the finished piece, reminds me of old military gear. Cool.
Big up to trendyironicname for Hammond dodging too.  Looks pro and pretty, and fit-for-purpose, without conforming.
phector2004
Rick, that looks pro! What's the current draw on it, now that it's got both a 1044 and a filament?
Free electron, very cool build! Where'd you put the transformers??
Also, what enclosure is that? I've been looking to house a small amp project for a while now...
~arph
Quote from: Haddock on February 26, 2011, 12:55:06 PM
system.
Greetings
Urs
Holy cr@p  that's primer! I did not see it as I weren't expecting it! Wow.. nice job, good idea too. Well worth the try on my next build.
Do you have a link to that german forum?
Cheers!
Galego
Not much for imagination today, just some polished enclosures.
I think we'll need to call Nasa to decipher this one.  :icon_mrgreen:
Haddock
#15413
@ deadastronaut
:D, i like the black one's.
Quote from: ~arph on February 26, 2011, 02:38:17 PM
system.
Greetings
Urs
Cheers!
Yes of course... http://forum.musikding.de/cpg/thumbnails.php?album=501
Greetings
Urs
@haddock... :icon_mrgreen:
aha...i feel a bit of pot butchery coming on... :icon_wink: :icon_cool:
free electron
Quote from: phector2004 on February 26, 2011, 01:35:28 PM
The enclosure is Hammond 26827PSLA, i bought it at elfa.se
The power supply pcb is on the bottom plate (added one pic to the post above).
1878
Quote from: deadastronaut on February 26, 2011, 04:12:18 PM
pot not pat........ :icon_mrgreen: :icon_mrgreen: :icon_mrgreen: :icon_rolleyes:
Perrow
Quote from: markeebee on February 26, 2011, 01:30:40 PM
It's a small network switch, I like the humor of putting a switch on a switch :D Maybe I should have gone for a A/B/Y in there.
My next (stomp) project will be four circuits in a larger network switch. Current list (might change) is LPB-1, Orange Squeezer, Little angel and some fuzz, possibly another Trotsky. I don't dare putting a Tiny Trem in there, might get four ticking curcuits.
mine doesnt tick!.. ;D
