ayayay!
Quote from: glops on June 22, 2011, 03:02:54 AM
Quote from: Le québécois on June 21, 2011, 04:25:07 PM
The layout was printed on AVERY transparent sticker and clearcoated many time
That is SICK.  Insane!
Irony:  A build called "Too Many Knobs" that has none.  Nice work!  Well done!
Regarding the Avery sticker paper, where are you guys finding it?  All the stuff I've found is opague.  I want transparency clear!  It says it's clear, then you peel it back and it's anything but.
The people who work for a living are now outnumbered by those who vote for a living.
~arph
Quote from: ayayay! on June 22, 2011, 10:12:20 AM
Yes, WHERE!  ;D
Le québécois
[/quote]
I send my layout to a copy store and they did it for me. I remember that when I looked at the transparency, It was not that clear (it was frosty). I tried it anyway because this is my prototype (I plan on enlarging the multifx with phaser, flanger double delay taptempo stuff...). In the end when I stick it on the multifx, it was still frosty whitish looking but after the clearcoating (Krylon stuff) the frosty disappear.  I think that the mm or so of clearcoat change how light is diffracted and it somehow filtered out the frosty color. It even gave a darker look compare to the edge of the pedal where there was no sticker.
aflynt
#16703
Quote from: ~arph on June 22, 2011, 10:22:35 AM
Yes, WHERE!  ;D
I've had good results with this stuff and their 'UV laminate spray' for clear labels on a lighter color pedal.
http://www.texascraft.com/hps/product.php?productid=17525&cat=253&page=1
Example:
This is also pretty cool for a silvery holographic look:
http://www.texascraft.com/hps/product.php?productid=17551&cat=262&page=1
Example:
And this works well if you're doing a more graphical design on a white background (it also works fine without an overspray if you're really lazy like me):
http://www.texascraft.com/hps/product.php?productid=17514&cat=249&page=1
Example:
-Aaron
ayayay!
Those look great and thank you for the links!
caress
Quote from: glops on June 20, 2011, 03:20:39 PM
Thanks, man.  I've been using spray cans by this company, Montana.  Great but expensive paint.
montana is excellent.  been using that paint for a few years now!
Güero
Curing the infection one bullet at a time.
glops
Actually, the Fixx Fuzz, the Fuzzrite variation with the boost on the front end....
tuckster
Fuzz Face (madbean Zygote)
glops
Quote from: Slade on June 23, 2011, 01:09:35 AM
AWESOME!
Thanks, Maestro!  All I do is reverse etch thanks to you!
Quote from: deadastronaut on June 23, 2011, 07:15:48 AM
^ yeah!... :icon_cool:
Thanks!!!
darron
again, i didn't build these. they are by Shaun Klinger. but i reckon that i get to show them off because i helped with setting up the powder coating and making the plaques for them!
^and your 'trademark' 10mm led!. :icon_wink:
btw, are those 10mm bezels plastic...i couldnt find metal ones. :(
darron
Quote from: deadastronaut on June 24, 2011, 03:32:24 AM
alright... so i've taught him a thing or two (:    glad someone noticed
they are metal of some sort plated in chrome. i get them from a local shop: http://www.altronics.com.au/index.asp?area=item&id=Z0230
John Lyons
Basic Audio Pedals
www.basicaudio.net/
Keppy
Yes, WHERE!  ;D
Small Bear sells adhesive transparency stock. Http://www.smallbearelec.com/Detail.bok?no=1069
I've had mixed results using it for graphics (he sells it for PCB making). Sometimes the adhesive reflects a bit unevenly, and sometimes the surface reflects light a little funny, but both problems are mitigated somewhat by clearcoating. Give it a shot with a heavy clearcoat and it might do what you want. Just avoid air bubbles (obvious, but tricky  :icon_confused:).
Brymus
Hah
Fuzzes,I just did a few for the local ax slingers.
For Fuzz: Volume down Fuzz up,For Clean Boost: Volume up Fuzz down
Here is my personal Fuzz
I need to learn how to cut my corners better, but I like using the decals ALOT better than other methods.
Brymus
My TS808 Clone
So after a week of making fancy graphics with fantasy art I instead went GREEN
tasos
yep!green is great!
and the fuzz also dude!
you both did great wiring job! ;)
