Ummagumma
#17740
Quote from: Renegadrian on October 18, 2011, 03:27:18 PM
That rangemaster is awesome!!! It deserves an "almost 10", if only you didn't put the white switch washer!!! Also I see a little triangle just under the knob, guess it had to be lowered a little...so it's almost 10...minus those two inperfections!!!
:) well originally it was designed for these knobs (which I currently don't have) that's why arrow should point the current number, but before I order one, I should check the scale to match arrow position. This knob is just temporarily, so don't worry.
guitarmageddon
Those Rangemasters are slick!
Here's my latest Range-Bender, (Rangemaster and Tone Bender II Reissue)
nexekho
I likey that!  Are the perfboards held on by the solder joints of the potentiometers?  If so, did you bend the pot legs to get that angle?  Or are they PCB mount pots?
I made the transistor angry.
guitarmageddon
Nothing as sophisticated as that, just on one stand off and some double sided tape on the back of the pot ;)
blooze_man
Are the ICs part of some sort of power filter circuit?
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
guitarmageddon
The ICs are voltage converters to provide -9v.
blooze_man
Ooh. That's pretty cool.
tiges_ tendres
Quote from: guitarmageddon on October 19, 2011, 01:07:28 AM
Did you need to use two converters for that?  Couldnt you build one, and just tap the supply to both pedals?
Try a little tenderness.
Barcode80
Quote from: tiges_ tendres on October 19, 2011, 12:13:03 PM
It depends on the current rating of the effects you are powering with it. Two FF's or two rangemasters? Yep, absolutely. You just have to make sure the current you are drawing with the two circuits doesn't exceed the current rating of the voltage converter chip, or you will be replacing them often :)
LaceSensor
#17749
EchoBase with all the mods:
RingStinger (not done any decal yet - and have since sourced a seventh matching knob...)
Hard work!:
Working on a number of other projects reports soon :)
Read more here if you feel inclined: http://hownotomakeapedal.blogspot.com/
snarblinge
Very nice echobase. out of interest.
where did you put the FX loop? and did you find you needed to tame the dub madness toggle ( I found only a momentary footswitch useable unless "leaving stage") and where are your mods, I made up an entire daughter board, yours looks very tidy inside.
b.
snarblinge.tumblr.com
LaceSensor
The FX loop is off the Level Control.
Every repeat goes through the loop once. Its cool with a phaser, for example.
I didnt do anything to tame the dub switch, it was just added for completeness. It does go very loud and crazy quite fast, especially if you remove the diodes with the other switch.
Dunno why you needed a daughter board, all the mods can be tack soldered (resistors, diodes, and the standard switch wirings). Thats how I did it anyway.
rugeb
My DOUBLE FUZZ (handmade)...
rugeb
ShortScaleMike
Amazing Echo Base!
Guts:
LaceSensor
Quote from: ShortScaleMike on October 21, 2011, 05:51:16 AM
Amazing Echo Base!
Compliment indeed coming from you. I see you have PCBs for your Dreambox now. Are you moving other designs onto PCB? Are you planning to sell PCB?
Cheers Mike!
Ian
ShortScaleMike
I have designed a few PCBs for my more popular stuff, once I have ordered test batches to verify they're correct I'll probably move to them for those pedals, but I'll be building on veroboard for a while yet!
As for selling them, I hadn't really considered it, but the designs are on Batch PCB so I could enable you guys to buy from there if you wanted.
LaceSensor
I'd build the dream box for sure... :)
Strategy
Newest build. Lovetone "Brown Source" clone. Was originally going to sell PCB but VERY glad I built it out. Subtle musical overdrive that sounds great on everything. Currently using on Fender Rhodes piano with my band. The bizarre pot layout is due to the board mounted PCB and pretty big PCB size. I think I am going to leave the enclosure raw/unfinished. I recommend this project!
Can't do gut shot today as I left all the screwdrivers in my work space away from home...
Strategy
www.strategymusic.com
www.community-library.net
https://soundcloud.com/strategydickow
https://twitter.com/STRATEGY_PaulD
AudioMime
First Build! :)
Karaoke Party! :D
I finally got it working! ;D
Harmonic Jerkulator coming next.
AUDIO MIME
Quote from: rousejeremy
Stick the Tremulus Lune in a Feedback Loop and your neighbors will call the cops on you. Which will be awesome.
