mills
I was losing my mind trying to debug a simple build that I've built similar versions before and cant make the stupid thing work.  So, to relieve stress, I decided to make my first filter, a  DOD FX25 with a mod or two... perf'd, boxed, and closed it up.  Pluged it in and it worked with no problems... which actually makes the other pedal that much more frustrating.
...and I  had to vent somewhere!
The solderside is a little sloppy ( and missing about 3 power connections)... I arbitrarily decided to use some random and oddly sized caps I had floating around and threw my layout off a bit while working or it'd be tidier.
Going to maybe try making my first waterslide decal.  If its a powdercoated enclosure, can I just clearcoat over that?
Scruffie
Ohhh my wiring pride.
Oh well, i'll just have to end it all now.
iq01221
I'll make a poster with this one, definitely my fauvorite!!! ;D
ShortScaleMike
Rev2 of the DreamBox PCB design
Keppy
Quote from: mills on November 30, 2011, 10:50:22 PM
Yup, I do it all the time.
richon
Maybe not a pedal/stombox PCB, but a work in progress (50W 6L6 amp, this is the preamp an Phase inverter part)
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
kato
#18107
Quote from: Scruffie on November 30, 2011, 11:10:10 PM
:D  Your wiring is gorgeous of course. Wiring is neater than it looks just struck me as an instant classic. I'm lobbying Small Bear to carry plastic meatballs to toss into my spaghetti bowls. I come from a strictly utilitarian build ethic, out of sheer necessity, so I'm in awe of the professional results here.
I should probably introduce myself. A google search dropped me into page 750 of this porn wonderland. I read to the end, totally amazed by the results you guys are achieving, and digging the encouraging, supportive vibe around here.
I've clearly gotta up my game if I want to hang with you dudes.
I'm Kato from Indianapolis. My sh*t looks like sh*t. It works great and sounds great, but until now I wrongly believed pro results were out of reach of the average DIYer.
Typical builds of mine have no stompswitch, no battery clip, and no indication of what's inside.
I just learned this week that standard 9v middle pin is ground. Mine are wired positive center to work with cheap answering-machine DC adapters. Hope you don't mind me sullying your gorgeous model porn with these skanks.
Here's a Craig Anderton Bass Fuzz (bottom) and DOD250 top:
Sometimes I get all fancy and use spray paint and sharpie:
Then I crammed a DOD envelope filter into a tiny enclosure. Labeled with iron on toner:
Then I bought a pack of waterslide to label a rangemaster:
And now I'm here. I guess it's time to try my first enclosure etch.   :icon_eek:
If school won't teach you how to fight for what's needed
They're teaching you to go through life and get cheated.
'kato' sometimes i get fancy....that made me laugh out loud... ;D
i like your builds...and humour..welcome to extreme pedal porn... ;)
snarblinge
welcome Kato, what is the small enclosure? looks flatter and wider than usual? or is that just the pic?
b.
snarblinge.tumblr.com
Renegadrian
yes, tell us more!!!
some of my latest...
OCD v.3
OCD v.4
Delay with switchable time pots
Buffer-Booster as discussed HERE
Electradrian (my modified Electra, as the name suggests)
cool builds adriano;  ....i like the no bezel look too, i do that nowdays...... :icon_cool:
Renegadrian
Thank you Rob, glad you liked them - I like to use those flat fresnel lens they have @ Banzai.
gotcha:  yeah ive seen those..hmmm....may have to get some...cheers man. :icon_cool:
kato
Quote from: snarblinge on December 02, 2011, 05:09:58 AM
Thanks for the welcome. It's 3.9" x 2" x 1".  I got it from Jameco in 1998; it was their cheapest metal enclosure which appealed to my cheap side. It sat around for 8 years because I couldn't fit anything into it.
It seems to be this enclosure although it came with a perfboard cut to size so it might be slightly different. Dimensions are the same.
DavenPaget
Quote from: kato on December 02, 2011, 07:19:32 AM
Appears to be a 125A clone  :icon_lol:
Hiatus
Güero
Housing a Bartolini NTMB. You can see the black epoxi block.
Curing the infection one bullet at a time.
skullservant
Just finished this one up tonight. It's a Wooly Mammoth. My first commission build!
tasos
skullservant
Have you grounded your enclosure? ???
