lespos
Lemon Screamer (a.k.a Tonepad's SinAmp). A litlle bit pokemonish  :icon_mrgreen: Yelow knobs - bypass, red - on.
rest of pics here: https://picasaweb.google.com/105256914421124922158/LemonScreamer?authuser=0&feat=directlink
Greenmachine
Excellent pictorial of the lemon screamer build!!!
haveyouseenhim
What's your method for the slide switch holes?  I always have to use my dremel to rough-cut it and then come back and do a lot of filing to square it up. Please don't say lasers :icon_eek:
http://www.youtube.com/haveyouseenhim89
I'm sorry sir, we only have the regular ohms.
Frances Rhodes
Quote from: haveyouseenhim on November 23, 2012, 07:35:20 PM
i know there are drill-bits made to do square and rectangle holes. i saw them in professional stores in france, and online (on the Würth website if i recall correctly). i believe they are pretty expensive and rare...
"If it's too loud, you're not too old, it's Alancka Effectors."
https://www.facebook.com/alancka.effectors?sk=info
haveyouseenhim
Quote from: Frances Rhodes on November 23, 2012, 09:03:08 PM
Drill bits?    :icon_confused:    I wonder how that works?
Frances Rhodes
Quote from: haveyouseenhim on November 23, 2012, 09:09:34 PM
as far as i can remember, they have a very weird shape. looks like there are some videos on youtube about this, try "square hole drill bit" and you should find information and images!
pakrat
Quote from: lespos on November 23, 2012, 05:14:59 PM
Simply amazing!!
Jdansti
Quote from: Frances Rhodes on November 23, 2012, 09:31:47 PM
The bit is special and it has to move a certain way to cut the square hole. See: http://www.mikesenese.com/DOIT/2011/10/drilling-square-holes-with-a-reuleaux-triangle/
haveyouseenhim
Quote from: Jdansti on November 24, 2012, 01:22:04 AM
Yep   I managed to find the second video from that page on youtube a few minutes after Frances mentioned it.
It looks like you HAVE to have a special milling machine to use it.
lespos
#20709
No, it's not a laser cut :) I made it exactly how you describe - micro miller, and then corners with file. Actually there is no need for micro miller at all. All job you can do with files only. It's just take a bit longer time.
I using this one miller http://www.proxxon.com/eng/html/27110.php
pinio
ashcat_lt
Diseased Dire Rat
Thread on another forum about the circuit.
1337DR1V3
Which is apparently almost exactly the same as the Gruntbox.  That might have saved me some development time...
Here's the thread.
And a thread including a demo sample of both.
midwayfair
SmoothAction
Yo! Here's an Orange Squeezer using the tagboardeffects vero layout. Sounds f'n clean, cleaner than my GGG board I remember... Absolutely no distortion, but havent messed with the trimmer much Don't need to. Superb layout.
I used a 1n914 diode instead of a 1n34a with no problems.
Right as I hit the sweet spot on the trim, I pulled out the flathead and off came the top white part. Oops.
Had to flip around my transistors.. oops again.
Experimental enclosure. Other than that, a fun and great sounding build.
8)
"Never heard a man speak like this man before, never heard a man speak like this man before. All the days of my life ever since I've been born, never heard a man speak like this man before."
LucifersTrip
always think outside the box
digi2t
Just a little counter punch to all the pedal jabs we usually get here. We've got pedals... now how about some power....
Geofex Spyder times two, in one box. They're upgrading all the PLC comms at work, and I managed to score a nice Modicon Modbus repeater. Everything is mounted on one big vero board.
We will now return to normal pedal programming.
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
darron
Quote from: digi2t on November 24, 2012, 10:03:07 PM
i think you're going to need a dedicated circuit breaker if you plan on using all those transformers with full current draw. did they need to be THAT big?
your pedals will never be hungry again.
digi2t
The transformers were a good deal.
There's a hydro electric dam not to far from here.
Must.... have .... more ....power..... :icon_mrgreen:
Dead End FX
That's one beast of a power supply, nicely done. I've got most of the bits gathered to put a smaller-scale Spyder of my own together but am unsure what to do about fusing, was wondering how you went about fusing the circuit(s)?
dave
ashcat_lt
Power?
Hope I haven't posted these here before.
Also, 1337Dr1v3 has the exact same thing built in - including the 5 outs.
