jhferguson
This may be a dumb question but, how did you all get your paint to stick to the aluminum boxes? I sand, primer, and paint and it peels off every time.
Govmnt_Lacky
Quote from: jhferguson on February 04, 2013, 02:53:34 PM
Check to make sure your primer and paint are compatible  ;)
MmmPedals
What kind of primer do you use?
Probably should start this in its own topic.
lietuvis
Here is my first time project with smd parts of THAT4301 compressor based on Carl Martin compressor/limiter schematic. For power I used 2W dc-dc converter NMH0515SC. For PCB files in sprint layout PM.
And guts
Perrow
Looking nice the lietuvis, was the SMD components hard to work with?
lietuvis
To Perrow : Thanks, no it's not difficult at all  smd was even easier than thru hole, did not have to drill holes, with fine tweezers and flux and not fancy iron solder and some online tips worked fine, not like factory soldering but good enough for diy pedal. to me key is flux and regular solder tip cleaning.
pickdropper
Lietuvis, that is a very nice build.  Great job with the SMD on the etched board.
midwayfair
I don't believe I've seen an SMD etch before! Nice job, lietuvis!
Jdansti
Whoa!!!  I've glanced at the board a few times and just realized that I was looking at the top of it!!! :icon_eek:
Very well done!!! :D
lietuvis
Thanks for comments, as I say I did really enjoy doing SMD, think all my next builds are going to be SMD, makes large schematics to fit on fairly small board, thous in to small enclosure. It somehow was easier to design the board itself, you can run resistor right underneath of film capacitor or within dip IC, I have ever soldered QSOP package without fail, removed bridges with desoldering bride and yes use enough flux. Here is some more pics:
Almost completed PCB stuffing
When I drilled holes in the enclosure I realised the pots will not fit for about 2,5mm from the top of enclosure to be PCB mounted, eventually I had to flip them and run the wires as in final version
dromilious
Nice Job man! As i can see you use a relay for switching ?can you please tell us more info ?
lietuvis
To Dromilious: the effect switching is done by dpdt heavy duty switch and it's not true bypass effect, but the buffer(or a gain stage approx X5) does not introduce noise to me and its a hi Z input, if you thinking about that black relay size component then it is a 2W dc-dc converter NMH0515SC to power up the circuit with bipolar 15V supply from 5V. The 5V I get from 7805 regulator mounted directly to enclosure which gets feed from 9V adaptor.
lietuvis
I get a lot from the forum so I more than happy to share my project.
Link to schematic and PCB files in Sprint Layout format for THAT4301 compressor, feel free to build it or modify :
https://www.dropbox.com/sh/er0ucqf9601wpc1/pNfdoGq-yV
free electron
Nice work Lietuvis!
Traco Power makes nice DC-DC converters which can be used to generate bipolar 15V directly from 9V, without the need to bring it down to 5V. I have used the TMR3-1223 in one of my latest VCA based pedals, worked nicely!
And here is my version of the THAT4301 compressor, soon to be a part of my new rackmount bass tube preamp:
Perrow
lietuvis
+1 WOW . I asume you going for full future compressor with attack and release and soft-hard knee? I think I need to grow up to start making double sided diy PCB. Are you using one of the Ampeg schematic? I can see large inductor. Actually I was thinking to build one svt 3 pro preamp and started pcb design for it, all on one board except controls to be on separate board, maybe one day...
vintageRigs
vintageRigs
Sorry...Here it is.  The Fuzz.  Fifth build, based on Tim E. TMK, but with a twist (less knobs).  This is my cleanest build so far, so i am showing the guts!
Guts
vintageRigs
