Focalized
#22080
Quote from: Magnus on June 07, 2013, 05:11:01 AM
That's just silly with the wires. But I love it. I need to see a construction video of this. I want to see the meticulous measuring and bending of those wires assuring you are not a machine.  Along with Basic Audio pedals if you know the stuff.
And like how the layout is a mess but the pedal is perfect.
ch1naski
Hello,
nice pedals and etchings!
Nothing new from me but I replaced the pcb in my first Fuzz Face I built years ago.
I have posted the pedal here so I don't do it again, but here's the link to the galery of this pedal: Woodface
...now it has a Pertinax-PCB with Mojo-Parts  :)
Here's the layout: Fuzz Face with Mods
Greetings
Magnus
That is sweet guts, there.
Mockingbird wish me luck.
Magnus
#22082
Thank you for your kind words  :)
I build pedals since 2004, so there were some years to do some try and error...
Knowledge grows with every single project, even with some guitar-cable-soldering...
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
rousejeremy
I would love to see a video of you doing your offboard wiring.
Do you wire it outside the box? What kind of wire stripper do you use?
Consistency is a worthy adversary
www.jeremyrouse.weebly.com
Magnus
#22084
Hello,
I mostly wire my pedals inside the enclosure except the pre-wiring of potentiometers and toggle-switches.
I don't use a wire stripper, I remove the isolation of the cables with a small side-cutter (like this).
It takes some time to try on the first few wires, but once you got it you won't damage any single wire of the core.
...and you are much faster and don't need an extra-tool  ;)
Yes, a video is always interesting but I am sure that it would be a bad record
because I don't have a very good recording-quality on my digital-camera
and I don't know how to make a good viewable record without camera-juddering...
Greetings
Magnus
rousejeremy
Nikolay
hi guys
This is the next custom project pedalboard from me
At this time this is just a 3D, but after momth this will be ready :)
There are 2 boss pedals, a booster and a switching logic+ transformer Di outputs
Niki
rousejeremy
Wow. Is that a DIY Tuner!?!?!?!?!?
MrStab
a Small Time Delay i built for a friend. called "F*****' Delay", to deviate from the usual witty puns i call these things.
i wasted over £20 and a week on labelling disasters, so in the end i just scratched it all off. i'll pretend i just filed off the serial numbers because i'm a bit G.
Recovered guitar player.
Electronics manufacturer.
It's slick like that. Raw utility can look elegant.
gcme93
Quote from: rousejeremy on June 08, 2013, 10:11:39 AM
QuoteThere are 2 boss pedals, a booster and a switching logic+ transformer Di outputs
It looks like he's Frankenstein-ing a Boss tuner into it. Hopefully he'll change the boss pedals to true bypass and put a decent buffer at the front of all of this ;)
Very nice design Nikolay!
Piss poor playing is why i make pedals.
pickdropper
rousejeremy
@pickdropper: hey, give us mere mortals a break!   :D
MrStab
i'm constantly amazed by the meeting of electronic nerdery with sheer artistic brilliance in the stompbox-building community, particularly here. if only my own art skills weren't purely "abstract" lol. outstanding work, Pickdropper!
and cheers, Gary!
stallik
Pick dropper  - I never tire of seeing this magnificent build. Each time I see it I decide to do something similar but I always end up with something more akin to an egg box full of spaghetti!
pickdropper
Quote from: stallik on June 08, 2013, 02:38:11 PM
Thanks guys.
This one have a few subtle changes from the first one.  For the fuzz, there are actually two separate boards, a screwdriver and a muff.  The toggle switches between them.  There is a bi-color LED to indicate state on that one.
I also switched the phaser from a phase 90 to madbean's cool Maestro rebuild.  I also changed the plates around a little bit and made the LEDs backlight the bottom plate instead of coming out to the top.
stallik
Sorry, didn't appreciate that this was a new one.. Truly beautiful
pickdropper
Quote from: stallik on June 08, 2013, 04:13:39 PM
Oh, certainly not a problem at all.  I just thought the differences might be interesting.
Thanks for the compliments.
Govmnt_Lacky
@pickdropper
Just out of curiosity...
How much do you normally get for that build?
