bloxstompboxes
That is one of the coolest things I have ever seen.
stallik
Quote from: Luke51411 on November 16, 2015, 08:17:45 AM
Wow that looks great! What are the gears fixed to the enclosure with?
Probably steam. Looks great :)
Schizo910
Quote from: Granny Gremlin on November 16, 2015, 08:06:22 AM
Hey cool build.  I'd worry about that arm coming off the black cog in the middle getting stomped, but that light is bloody cool; what is it?
Thanks! That arm can rotate, so it's not comming near the stomp. The light is a normal red LED, but there's a tube with a spring above it which gives it that cool effect.
Most of the gears are held in place by the screws from the switches and potmeters. The others by bolts and glue 😋
Granny Gremlin
OK, just a bloody large LED (a local store here has those); thought maybe it was something else - looked kinda conical vs LED shaped with the spring on top of it.
my (mostly) audio/DIY blog: http://grannygremlinaudio.tumblr.com/
Schizo910
Quote from: Granny Gremlin on November 16, 2015, 01:35:55 PM
It's not even a big one. The small tube magnifies the light. It's luminating!!! 😄
Pettol
Cool, Schizo910!  Nice steam punk pedal.
pickdropper
This is a P90 and CE-2.  Switching jacks used so that it can be used as two separate pedals if desired.
bloxstompboxes
Quote from: pickdropper on November 22, 2015, 10:14:15 AM
That's the same CE2 board that you used in a 1590A if I remember correctly,right pick?
pickdropper
Yep.  It's also the same P90 board I used in a 1590a build.
stallik
Really like the design pickdropper and soo neat
jimilee
This is a bloodstone phaser from lectric-fx and a Madbean laserwolf which consists of an overdrive, delay and phase 90
Pettol
Nice work Pickdropper! So tidy and clean!
Really nice builds Pickdropper and Jimilee.
It's been waaaaaaayyyyy too long since I've posted pictures of builds on here, because frankly it's been waaaaayyy too long since I've finished anything :P But this is a Rebote 2.5, nicknamed "The Gekkoplex," with a safe/standard/infinite/oscillation mode rotary switch, a mod my friend described and had me breadboard until I "got it right." Finish is CNC engraved on a powdercoated box (not my favorite, but his request). And just after I finished boxing it he said "You left room for a battery, right?" ::) Needless to say, there will be no gut shots.
Bret608
Here's a fun build I did recently with an IvIark layout. It's the D*A*M FZ-673 circuit, a cool, loud, dark-sounding take on the Zonk/MkI typology. I made a few tweaks to get things working the way I wanted with my transistors (AC128s and OC47). I even got the O.G. Dollar Tree batteries like Jerms!  :)
LightSoundGeometry
#26095
a rangemaster that i did, she turned pretty good. voltage got to 5 or a little higher is all could get out of it but sounds great none the less
where do you guys get that shielded cable like that? i see it in almost all of the builds..it looks a lot nicer, and easier to work with, than the stuff I bought
Bret608
I got that shielded cable from LIC Pedals, who has a store on Ebay. He has a lot of other cool parts too.
Cool Rangemaster!
LightSoundGeometry
Quote from: Bret608 on November 24, 2015, 05:11:59 PM
Cool Rangemaster!
Cool. I know chris from youtube demos and his youtube channel. I didnt know that he carried the cable! He is one of the good guys emailing me with help & advice on my tonebender.
I will place an order with him in the next few weeks and get me some of that wire. not that the stuff fro SBE is bad or anything, this stuff just looks nicer and easier to work with from the pics. I dont need a whole lot, just enough to build 2-3 pedals for myself.
thanks for the kind words and heads up.
Telvis
gorgeous! nice work Pick Dropper
