Ben Lyman
My first delay pedal, much like a Mad Bean Sea Urchin but with some changes due to components on hand and my regular junk that I throw on every pedal I make.
        -S. Vai
GiovannyS10
You did a very good work, Ben. I liked specially your way to paint. Good work!
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
www.instagram.com/allecto
Ben Lyman
Thanks GiovannyS10! It's not perfect but good enough for me. I'm really trying hard to get the hang of this "hammered" spray paint but it's tricky. The bottom plate came out perfect though  :P
        -S. Vai
hylandren
Nice looking build!
Quote from: Ben Lyman on November 02, 2016, 10:13:17 PM
Agreed. Your hammer-tone finish is waaaay more evenly "hammered' and better looking than I have ever been able to achieve with that stuff!
hyrk
Hi, I"m new, some of mine, thanks to diystompboxes.com.
I test some technics.
My instagram profile : https://www.instagram.com/benumb_/
Quote from: hyrk on November 04, 2016, 10:23:44 AM
Welcome :) Really great looking builds, I particularly like this one. Look forward to seeing more from you ;D
rutabaga bob
Fuzz Factory - finish from Mammoth Electronics.
Life is just a series of obstacles preventing you from taking a nap...
"I can't resist a filter" - Kipper
It's been a while since I've actually finished anything (long story ::) ), but this was a build to replace one I sold to a friend off my gigging board. It's a combination reverb (GGG D-Verb) and clean boost (LPB1 wired point-to-point on the back of the pot). I've always been super jealous of Hexjibber's builds, so I wanted to try the multi-color fade thing, but apparently dark blue to light blue doesn't turn up that well :P The engraving is Mongolian block script, courtesy of the missus.
darron
hyrk
Quote from: vigilante397 on November 04, 2016, 11:00:42 AM
thanks for your answer ! ;)
nice knobs on yours !
Willypp
Gudday all.  Here's Stealth.  Smoothie, Glam, Smalltime + tap, Equinox II.
The tap is from http://uk-electronic.de/onlineshop/product_info.php?cPath=105_195_352&products_id=3099&osCsid=0622e90a18403e6cf9f89e22f30a9aa6
Etching primer with clearcoat, then laser etched.  Not recommended really, it came back from the engraving with some weird crazing in the clearcoat.  Polishing didn't get rid of it, so I was forced to cut it back *very* lightly with wet/dry sandpaper and then polish with the cut/polish compound.
As a result, the smaller text isn't as sharp as it was.  It also had lots of little bare dots around a few of the letters, so these have been filled in with a fineliner texta.  These pics are the before photos, as tightening the nuts causes the finish to chip off in places, so I've taken photos before all the extra fineliner.  Additionally, the pot shafts are different lengths, so I've put the knobs at the same height for the photos and have now shoved them down lower..
The Smalltime on vero is now playing funny buggers, so I may replace it sometime or at least check the solder joins.  I don't remember the Equinox being so distinctly delayish either.  Anyway, it's working, more or less.  I can see myself replacing the delay and reverb at some time.
The guts are ok, as far as these sort of things go.  Vero makes for a tough time making it look neat.
hylandren
#26811
vigilante397 and Willypp, you guys need to cut yourselves some slack! Those are both excellent looking builds!
Willy, do you mind saying where you got those cool knobs?
Sorry, me again :P A while back I was super busy and didn't want to start any builds for people so I sold a friend a couple of my personal pedals off my board and have just gotten around to replacing them. This is my new Tremulus Lune built off the fabulous Tonepad PCB. I decided to try another multi-color job, this time just using every single color I have in my garage that isn't already on my pedalboard. I'm pretty stoked about how it turned out ;D
Nice and tidy handiwork again, Nathan.
See what I did there?  ;o)
Willypp
QuoteWilly, do you mind saying where you got those cool knobs?
Not at all.  I got them from Paul at diyguitarpedals.com.au
http://www.diyguitarpedals.com.au/shop/index.php?main_page=product_info&cPath=15&products_id=433
Pettol
Nice etch there vigilante!
just trying imgur...
without success it seems...hmmm...
Ben Lyman
Quote from: deadastronaut on November 10, 2016, 07:06:00 AM
Tiny pic seems to have taken the piss... lately I use this: https://postimage.org
        -S. Vai
Your problem there is that you were trying to post an entire album with one link. On each picture there is a button for "get share links," and you just have to select the BBCode for forums (and adjust for size of course), and it should work fine.
Perrow
Didn't know the Celts had a space program. The "dead" part of his name might, of course, might explain why they didn't push for media coverage.
