It's been a long time, but I'm finally getting back to pedals. I had built a couple of Freppo's Into the Unknown synthesizers for friends but I always wanted one for myself, so when he released his v2 boards I had to go for it. CNC engraving on a Mammoth powdercoated box.
It's good when you can treat yourself.  :)   Nice job, Nathan.  Like the marriage of the star-field paint job and your space design.
Yer spot on Nathan.
MuthaFunker Envelope Filter.
jimilee
That's killer!
Sent from my iPhone using Tapatalk
bloxstompboxes
Just a Timmy here. Somehow managed to make the bass cut just a bass and the drive is backward. Easily fixable. This build was spread out over like 3 months so I may have goofed on the enclosure layout, board, or whatever. Then again, it could have been the scheme I used. I've been so busy with the new job and kids; it could have been anything. I'm just glad it is done. Happened on a bunch of 47uF caps at a higher voltage rating for cheap, hence the biggun in the upper right. The 1uF on the left caused the lid to have to be modified. I finally remembered this board was originally designed for a 125b, lol.
thermionix
^ Reminds me of a question I've been meaning to ask folks here, is there a common enclosure size between 125B and 1590B, same general shape?  I've been using 125Bs mostly but they are bigger than necessary for many builds.  1590B however gets real tight real fast if you want to have room for a battery.
Quote from: Kipper4 on February 18, 2017, 02:59:31 PM
(s)he's got a footie for a mouth!
Cozybuilder
Clear shaft pots & knobs would have been nice, blue or green LEDs for eyes, and a red for the third eye. The Hinda Funker?
add4
Quote from: Galego on December 25, 2016, 10:00:48 AM
3D Printed wah:
João that's absolutely stunning [emoji28]
Envoyé de mon iPhone en utilisant Tapatalk
Mgt280y
Finally done the enclosure for the first pedal I ever built  :icon_redface: been in a bare enclosure for over a year
Loving lasers !!!
thermionix
Mgt280y
Yeah had some bits left laser cut and marked leather, with laser engrave powder coat not perfected yet but happy with how it came out
Quote from: Mgt280y on February 22, 2017, 04:18:26 AM
....  not perfected yet .....
oh, please. how much better do you need?
Quote from: thermionix on February 18, 2017, 10:15:00 PM
Perhaps consider a 1590BS.  It has the same footprint as the 1590B, but is 11mm deeper.  It is deep enough to allow you to have multiple stacked boards and even have a board over the stomp switch if you want.
Apparently, there is also a 1590B2, which is 7mm deeper than the 1590B.
Mgt280y
Things can always be improved, need to find something to make the engraved leather stand out a little better like the "rub n buff" type idea
MadJr
#27016
DBD clone and a Jfet boost
thermionix
Quote from: EBK on February 22, 2017, 08:55:15 AM
Thanks, I'll look into those!  The B2 sounds good for being able to stand the battery up on its "skinny" side.  Lay the battery flat in a 1590B and it takes up a third of the enclosure, and forces the footswitch toward the middle.  Not ideal.
mth5044
Quote from: MadJr on February 22, 2017, 10:33:07 AM
Nice. How'd you do the lettering?
bean
It's a Theremin with dry-through. Some issues to work out on this but it's fun to play. The box was done with Aluminum Black which is messy to work with but much easier than painting enclosures.
