Cozybuilder
Trace on paper, cut it out, trim to fit just right inside the lip, then use that as your pattern for your hard bottom. If you use plastic, you can aim the LED at it and have a nice lightplate. Hot glue should work fine for holding it in place.
Marcos - Munky
Thanks for the suggestion. I have a friend which works with acrylic, I'll see if I can get some spare cuts to make the bottom lid. So it will work as a lightplate and a kind of window to see the interior of the box.
brackets, Marcos, brackets! bend some L and or U shaped brackets, drill a footswitch sized hole in one, drill an L pair to fit under your in/out jacks (or DC jack (or the pots)), and put those other parts to doing some work. that way you don't have screw-heads messing your sleek lines.
a block of wood the right thickness, some clamps and a hammer, sheet metal from an old PC tower case. cut, bend, drill, tap some screw holes for the light/base-plate, and bob's yer unkle.
Marcos - Munky
Thanks for the suggestions, Stephen. I didn't thought about brackets. I will try with the next one, since this one was made in a way it's hard to take it apart - I used cheap jacks for this one, and add a little drop of super glue between them and the enclosure :icon_lol:, and to remove the dc jack and switch I need to desolder all the wires.
kind_shepherd
#27044
My Tone Bender MKII based pedals on russian military 1T308V transistors.
those are nice and clean looking builds, kind_shepherd. and welcome to the forum.
rutabaga bob
Very nice!  Welcome!
Life is just a series of obstacles preventing you from taking a nap...
"I can't resist a filter" - Kipper
Kingmafw
Very well made and clean build kind_shepherd. Like it very much!
What HFE did you use?
I still got 100 pcs of these Russian Transistors.
it is mei sizzen net to dwaen
Johannes Harald Kingma - FWS Pedals - Germany
kind_shepherd
#27048
Thanks guys!
hfe are 74, 85, 88 +-2
That seems best for me. But amost anything bethween 70 and 110 is well. More hfe - brighter sound.
Here's some funny demo
Benoi31
Love these tonerbenders! Really sharp and neat looking.
Zilla
I don't remember if i've ever posted in this thread before  :o
some of my recent builds:
Arcadiator
Blueberry Bass OD
Sansamp BDDI
Clone Theory
2-channel Diefet
pt2399 echo with modulation
Custom op amp muff with lpb and all sorts of other mods
Another op-amp muff with footswitchable mid boost
Dr. Boogie
Sweet Jesus Fuzz - modified Baldwin Burns Buzzaround with a Baxandall EQ
Soldano X88r preamp simulator
Elijah-Baley
#27051
Really great pedals!
I see the 2-Channel Diefet.
Quote from: Zilla on March 17, 2017, 01:41:45 PM
2-channel Diefet
I often wonder if there is some (easy) way to do what you did with any pedals: two channels with separated gain and volume.
Zilla
I'm sure there are ways.... whether they are easy that's another question ;)
Elijah-Baley
Is your way secret or you may reveal us? :P
Zilla
i bypassed the first gain stage for the "crunch" channel and changed q2 for something with slightly lower gain.
Elijah-Baley
Ok, thanks. ;)
I was thinking a way to get on the same "channel" separeted gain and volume pot for two different settings. Not very professional (or reasonable) but useful for sure.
Maybe I can open a new topic about it.
Bye!
GiovannyS10
Hey guys!
I have been a lot absent here, but its because i am working a lot. Now pics from my last two buildings ready to meet its new family...
I  hope you enjoy, guys!!!
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
www.instagram.com/allecto
geeze, you really are awesome, gio.
steveyraff
Customers picked the artwork for these ones so they ain't really my aesthetic designs...
King Of Clone with high gain mod to the right side, dual externalised diode toggle switches and internal presence trimmers:
Bluesbreaker and TS808 with a diode switch:
Steve.
www.outlandstudios.co.uk
Good job Stevey. Love the paisley print artwork.
