Funkymonk
#27120
BSIABII with contour pot in a 1590a enclosure.
Marcos - Munky
Nice first post, Funkymonk!
Another sardines can. This one is the Golden Dragon Overdrive by Andy (Dragonfly). Btw, what happened to him?
Gut shot:
Outlaws
#27122
Tone Bender MKIII
Got it powder coated.
Quote from: Outlaws on April 24, 2017, 10:41:54 PM
Tone Bender MKIII
I love you (because you are here and sharing with all of us), but please, use [IMG width=n] for the times that I am out of WiFi range*....  :icon_wink:
One quick question: Looks like your powder coat is inside and out.  Do you have any electrical connection to your enclosure for shielding purposes?
*I personally like n to be 350, more or less, depending on how much detail I need to show
Outlaws
Quote from: EBK on April 24, 2017, 11:56:11 PM
Tone Bender MKIII
Lol, I thought it was odd.
There is the jacks.  I had to re-drill the holes after.
Perrow
On a side note, using width does nothing to the image size except scale it to that width. You'll have to resize it to lessen the bytes required for the download.
Quote from: Perrow on April 25, 2017, 09:08:31 AM
I'll second this.
Bummer.  I thought it was a server-side resize.   :icon_sad:
Then I'll go with another suggestion: if using Imgur, tack on a letter to the URL, right before the '.jpg':
s = Small Square (90×90)
b = Big Square (160×160)
t = Small Thumbnail (160×160)
m = Medium Thumbnail (320×320)
l = Large Thumbnail (640×640)
h = Huge Thumbnail (1024×1024)
kaycee
Mk 1.5 Tonebender with an acrylic viewing window. Built on pad board, internal LED lights the inside up when on.
Top Gear Fuzz Sustain on vero from the Tagboard layout.
Love the window (router?).  I think it would be cool to continue the pop rivet thing instead of screws, but that's mainly because I'm a fan of pop rivets.  :icon_wink:
kaycee
No router, drill the corners, cut with a junior hacksaw and file straight. I think the riveter would shatter the acrylic but I might try it sometime.
darron
Quote from: kaycee on April 27, 2017, 02:31:29 AM
i feel that you should use minimum pressure with acrylic. enough to mechanically secure it, but anything further can add spider cracks (is that the term? little hair cracks) on the long-run.
GiovannyS10
Hey guys,
Here is my last one building! One more looper, and curiously it was my first building using millenium bypass, but worked very fine.
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
www.instagram.com/allecto
wowee! and not a sign of pink. [drilling the perspex gets it excited, once you then pop it with the rivett, it will crack, in my experience.]
gigo - mango millenium AB switcher?
Quote from: kaycee on April 26, 2017, 06:32:44 PM
I would normally say I can't stand Windows, but I'll make an exception this time.   ;D
GiovannyS10
Thank you, Marc!
Hey old duck, you are ever saying like my greater grandmother used to say "I want MANGOOOOOOOOOO!"
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
Refractions
Last couple of builds.
Dual Valvecaster - now sold.
TubbyTrem - Valvecaster with Tremolo.
TrueBlue
#27139
Here are my first 2 builds. A BYOC mouse and a GGG BMG violet rams head version. Still trying to figure out my third build.  Learning a lot about finishing and thinking about etching the next one.
