temol
Screamin Eagle preamp under slightly different name..
T.
diydave
A colorsound powerbooster clone.
Transistors: 2 x BC108 and a 2n5088
Voltage doubler made with a cd40106 and schottky diodes
mth5044
DIYDave ^^^ cool enclosure!
Plexi
To you, buffered bypass sucks tone.
To me, it sucks my balls.
creepingnet
First Pedal (Fuzz Pedal with a lot of cool tone/utility/sound modification features) I ever designed, built, and first PCB I ever etched.....not a 100% perfect execution but it works and sounds great and I used it at rehearsal last night as a regular sort of Fuzz and my god this thing kicks butt.
All that's left is some small tweaks and some graphics for it (I'm doing a Five Nights at Freddy's Themed graphics on this prototype, I named all the transistors after the animatronics during development to keep the gain stages straight in my head).  Some things I'm doing on the next revision is a better PCB (no scrub-etch method), simplified Momentary/Permanent switching scheme using 2 foot switches instead of 3, and proper taper pots (+ and - pots are to be Linear, not re purposed 1970's audio pots).
Plexi
Green Russian Muff.
A few extras:
- 3 clipping modes: Silicon, none, LED
- Mid bump switch
Buildtestrepeat
My old Valvecaster with graphics added that I didn't put on originally.
lars-musik
FINISHED!  For a guitarist with a Brunetti Singleman amp. We mailed a while, interviewed people with a similar setup (who in contrast to myself can play guitar well and have ears for pedals' sound details) and came up with a collection of possible matches. In the end, we settled on taking all of them.
NOw it is the CBS (clean booster, BYOC 27V Booster; switchable from first in the chain to last) ->  JRY (Jan Rayish Timmy) ->TMMY (guess!) -> Box of Rock (Drive side) -> DBS (dirty booster; SHO).
The enclosure is etched (I was afraid I wouldn't be able to control the process on such a huge surface but it is one of the best etches I ever made) and I am SOOO proud.
Lars, that is visually stunning and an amazing etch!
Plexi
creepingnet
Man, Lars pedal is what I aspire to someday.
New pic of the Fuzz, did some debugging last night.  This is my own crazy circuit only slightly derived off the BazzFuss circuit (it's like 5 of them cascaded into each other in a way, but sort of not as well).  The artwork was done by me, by hand, with a sharpie and has a adhesive backed Lexan sheet over it.  Yes, it's FNaF themed, make of that what you will, it was a bit of an "in joke" of sorts when I was developing this thing.  Plan to make a video of it at some point in the near future now that people can actually see where the knobs are set now.
thermionix
thermionix
Quote from: thermionix on September 23, 2017, 12:25:18 AM
Quote from: EBK on September 22, 2017, 06:03:15 PM
Quote from: thermionix on September 22, 2017, 06:01:21 PM
FNaF?
Now I'm even more lost.  Is that a cartoon or something?
It's a search result on Google's website.  :icon_razz:
Quote from: EBK on September 23, 2017, 06:09:03 AM
FNaF?
geeze, therm, even I know this .....
Plexi
After primer... things are getting some "color"  ;D
Time spent: 1hours.
Time used painting: 15min
Time used cleaning the paint pistol: 45min
I guess the effort cleaning and waste of thinner worth if you will paint >15 enclosures of the same color.
Quote from: Plexi on September 23, 2017, 10:23:31 AM
Time spent: 1hours.
you've forgotten to drill some holes, looks like.
italianguy63
Quote from: duck_arse on September 23, 2017, 10:49:09 AM
Time spent: 1hours.
No holes needed Ducky!   Plexi has figured out how to use "Mind Control" to make everything work..
That guy!!  :)
Nice work Plexi--
I do a lot of etching... I hate doing the prep (sanding the enclosures)....
MC
Plexi
No holes... wifi controlling, even with faraday (¿)
;D
Holes comes later!
I had not any trouble, or cracked paint doing it after.
