Quote from: duck_arse on January 14, 2024, 08:44:07 AMa bit of lego each.
I never thought of Legos as foot protection.
a matter of degrees, I suppose. Matthew, have we heard this christine beast in action yet?
" I will say no more "
sinthmart
I am interested in inventing and making sound devices.
Ben N
Is that supposed to be a bias meter? Cool idea, but I'm not sure how to read it.
Matthew Sanford
Quote from: duck_arse on January 15, 2024, 08:31:54 AMa matter of degrees, I suppose. Matthew, have we heard this christine beast in action yet?
Yes, well breadboard and my Pj pants were complimented! There is this video from the breadboard, using CV to twist knobs, in short bits.
I feel making the input buffer into a distortion + with an option to mix some into the output would give a less chop glitch option, but I've found a rangemaster before does quite a bit - no videos on that yet
"The only knowledge is knowing you know nothing" - that Sew Crates guy
Controlled Chaos Fx
Phend
Here is an Orange Squeezer.
Thanks GGG and Mark for the modified circuit.
And of course Rob.
Solderable BB, Built to schematic sans Bright cap.
Acrylic face plates with inlays.
  • SUPPORTER+
Do you know what you're doing?
Matthew Sanford
#29886
Quote from: Phend on January 20, 2024, 04:03:58 PMHere is an Orange Squeezer.
And of course Rob.
I've been wondering, how is solderable bb? I mean compared to Vero...
Ok, read on it so like super protoboard using jumpers or leads to connect?
Controlled Chaos Fx
Phend
#29887
Yes, jumpers on the back side.
I made my own layout.
Like it because it looks neat.
Yes, it could be made much smaller using other options.
But I like this.
I will never drag solder to make connections.
  • SUPPORTER+
Matthew Sanford
I think it looks great, and may be a better option than Vero with it's thin copper, vias and jumpers seems much better
Controlled Chaos Fx
Phend
The pots are mounted to the board so they take up 9 rows.
Is there a better layout, probably.
I haven't tried to cut a "row" like on strip board.
Never used any other type of board.
Make all my own layouts on cad and quadruple check on paper.
Then with dmm on the jumpers.
  • SUPPORTER+
Black_label_devices
And these are my effects, Boss CE-1 and Preamp from CE-1 Chorus :)
Phend
#29891
I just completed this DIY Foxx Tone Machine.
Thanks GGG for the circuit diagram.
Acrylic tops with abalone inlay. (Sustainable from New Zealand)
A few Fish and 280 Hfe transistors.
As Mark Hammer has suggested:
R7 and R8 are matched.
D1 and D2 are BAT41 and also matched.
R9 and R10 selected within 1%.
D3 and D4 are stock 1N34A I bought at RS in the 80's.
(470R connected from them to ground)
Great sounding, the controls work well.
Tone is what I consider backwards but works well. Edit, probably is correct.
Sustain adds lots of Volume which is controllable with the Level.
Octave is impressive, you have two effects in one box with infinite sounds.
  • SUPPORTER+
Quote from: Phend on February 04, 2024, 03:10:42 PMabalone inlay. (Sustainable from New Zealand)
When I was a boy in California, we used abalone shell for driveways, there was so much around back then.
sinthmart
Quote from: Ben N on January 16, 2024, 05:43:59 AMIs that supposed to be a bias meter?
Yes, this is the mode of the second transistor, which can be visually observed, which means it can be set accurately and quickly.
Phend
#29894
Working on a Tremolo build, here is a ~5 min video of making the top.
(Missed the first part trying to figure out the complicated movie making thing)
Cut all holes, raster text. Ready to install.
  • SUPPORTER+
bluelagoon
Hey Paul, What sort of laser cutter do you use to get those results ? and what would the minimum laser cutter requirement be for same results ? Looks a handy tool, just for making acrylic templates, shore would beat the router method I have been using, if it weren't too expensive.
Phend
The laser is 40 watts and can cut 10mm acrylic in a single pass at slow speed and max power. The acrylic I am cutting here is 3mm thick. Laser prices have come down. This 2005 Epilog Mini was rather expensive. Completely enclosed, air cooled, focus, cutting grid, etc. 25 watts would work, but it is the machine quality not the power that cost. I have paid for the machine long time ago with jobs.
  • SUPPORTER+
bloxstompboxes
And of course Rob.
That, my friend, is a work of art. Love the attention to detail. Orange tree branches to the controls, the acrylic, etc, etc.
hi guys, finished off a couple of 'pendulum tremolo+ pedals.
rustypinto
Quote from: Black_label_devices on February 04, 2024, 05:49:11 AMAnd these are my effects, Boss CE-1 and Preamp from CE-1 Chorus :)
These look silkscreened, is that right?
Quote from: deadastronaut on February 17, 2024, 08:53:37 AMhi guys, finished off a couple of 'pendulum tremolo+ pedals.
These look etched, is that right?
Quote from: Phend on February 13, 2024, 03:00:37 PMWorking on a Tremolo build, here is a ~5 min video of making the top.
Incredible, I love seeing new methods for finishing (my absolute least favorite part of pedal building).
I recently used a sticker, something i've never tried before. I only mention it because the method is a similar single-media simply placed on top. Makes a lot of sense with all the custom, durable, vinyl sticker options these days.
However, the application is still difficult with stickers, especially centering. The plate is nice because its fastened with screws.
