Phoenix
Quote from: Focalized on August 11, 2024, 06:34:24 PMThat's excellent. Show the insides. What is that box with the hex screws or nuts?
Whoops, missed your reply until now, guess something with the forum alerts has changed since I was here more regularly.
Anyway, thanks! It's just a regular 125B enclosure, and yes Tom has it right:
Quote from: ElectricDruid on August 11, 2024, 08:09:53 PMI'm guessing it's a PCB panel screwed to the top of the box for the graphics. PCB-as-front-panel has become quite popular as the range of colours and finishes (and the reliability!) has improved, both for pedals and for Eurorack synth modules in particular. Much cheaper than CNC'd aluminium and screen-printing, at least for small quantities (like "1"!!).
The buttonhead Allen screws in the corner keep the panel in place. I drill and tap blind holes in the aluminium. I've seen others use just pot/switch bushings to hold such panels in place, only for the FR4 to warp and "peel up" at the corners or get caught by shoes and snap. Anyway, the bushings on the 9mm pots I use aren't long enough for the thickness of enclosure + panel.
I don't currently have any pics of inside to share, not that there's anything interesting to see IMO. I do have some other projects to share coming up, I'll try and snap some interior photos for those.
Focalized
Shocktave sub octave fuzz.
Acapulco Gold / X-Fuzz
drdn0
Glow in the dark FA1-esque preamp
lars-musik
The 2nd iteration of my 4-in-1 project - a custom build for my guitar teacher - is ready and he even made a video for it. His idea was to have a pedal that works with most amps he'd find in the backline of future gigs. Usually, he uses a Fender Princeton Reverb, so Tremolo, Reverb, Overdrive (and Delay) was on his wishlist for a grab-and-go pedal. The first one I stitched together with PCB I created over the years, 3Verb, Vico Vibe, Jan Ray and Deep Blue (here is the link to the last post). Now I packed it all on one large PCB including relay switches, so the parts can also be remotely switched (Delay and Reverb are in one switching circuit. Turned out great. Now it even sports a battery (it draws a measured 100mA).
bluelagoon
Nice job Lars, I'm sure your guitar teacher was wrapped.
Wondering what type footswitches you used on it, they look momentary, of some kind, how durable are they ?
lars-musik
Quote from: bluelagoon on August 28, 2024, 08:45:20 AMNice job Lars, I'm sure your guitar teacher was wrapped.
Thanks! They are called "Vandal Protected Switches" (not, that I think Tim is somet kind of a vandal). I found them on ebay as a replacement for those super-expensive Lehle BTN switches. They take up less space than the regular momentary ones. I hope, they will endure what they promised.
Matthew Sanford
#30046
And video!
Not sure why C & Em, got stuck on listening
And ok nasty insides...got pcbs coming to make it easier...
"The only knowledge is knowing you know nothing" - that Sew Crates guy
Controlled Chaos Fx
zbt
Quote from: zbt on April 12, 2024, 10:55:34 AM
Quote from: Ben N on April 09, 2024, 06:02:17 AMHow doe the top hold up to stomping?
Quote from: zbt on April 07, 2024, 08:20:53 AM
This one might work, I might add rubber to hold the pressure.
May be Tuesday, cause is tuna time, meow
amz-fx
Full front panel sticker printed on an old Epson inkset printer.
The holes are already drilled and just covered by the sticker at this point. I will cut them out with an exacto knife when I am ready to install the pcb.
Other pix of my recent builds are in my instagram.
Best regards, Jack
is that real people generated, Jack, or the dread IA?
" I will say no more "
btondin
Simple ISP decimator clone:
Transistor-Transistor
This is my new unpainted prototype of my overdrive/distortion I've been designing for the past 4 months. I made a slight error when soldering it up(testing shows that a tranny is bad) but even slightly broken it sounds awesome.
I think I'm gonna use color coded knobs on all my designs now.
Why does man create? Is it man's purpose on earth to express himself, to bring form to thought, and to discover meaning in experience? Or is it just something to do when he's bored?
-Calvin, Calvin and Hobbes
And now the painted, working production model of my overdrive/distortion circuit
Matthew Sanford
Quote from: Transistor-Transistor on November 02, 2024, 09:49:18 AMI think I'm gonna use color coded knobs on all my designs now.
Awesome. Code them (I.e., red for gain, yellow for tone, etc) and then you'll know what is where at a glance!
Controlled Chaos Fx
Quote from: Matthew Sanford on Yesterday at 10:58:29 AM
Yeah! Yellow controls an input boost, red is gain, green is tone, and blue is volume!
But now I have to think of what the colors will represent in a modulation circuit...
Matthew Sanford
Right? I've done similar but has been Druid StompLFO in a couple so matching purpose was easy.
Controlled Chaos Fx
