Dragonfly
Quote from: bancika on January 15, 2008, 03:37:53 PM
what are those two black "things" on the board, look like M&M :)
transistors :)
Dragonfly
Quote from: GREEN FUZ on January 15, 2008, 03:42:12 PM
Yeah, them "black things". I`ve got a little bag of those. Unmarked, bar one which has me4003 writ upon it. Don`t suppose that`s what they are?
nope...
2N3569 and 2N3645
ezanker
Here is my antiquity fuzz:
I got rid of the gain pot setting it to max gain and then using the guitar volume knob to roll back the gain as needed.
Erik
bean
Quote from: Dragonfly on January 15, 2008, 03:27:38 PM
Quote from: Dragonfly on January 15, 2008, 12:24:41 PM
As soon as I get the technique "perfected" I'll post a "How To do EZ Swirls" thread...
Here's the one from earlier, after the clear coat...I'm making it for a friend...old school fuzz, no LED or DC Jack !  :)
Here it is all wired up !
And a sound sample...he wanted the big loose bottom of a germanium, with the "spit" of a silicon.... (don't mind my sloppy playing...I couldnt find a pick !)
CLICK HERE FOR SOUND SAMPLE !
So the knobby is for bias? That is one rude fuzz!
allmonochrome
Quote from: Dragonfly on January 15, 2008, 04:05:22 PM
nope...
2N3569 and 2N3645
any chance of a layout for this one?  ;D
niggez
i would be very interested in a layout as well!!
very much like the sound of this one!
mfergel
Quote from: kurtlives on January 15, 2008, 04:01:13 PM
Quote from: mfergel on January 14, 2008, 08:45:04 AM
Quote from: kurtlives on January 13, 2008, 11:26:34 AM
Quote from: mfergel on January 12, 2008, 08:01:15 PM
Well, my second etch didn't come out as clean as my first but it still looks cool enough.  I decided to etch the graphic of the MXR Zakk Wylde pedal.  Think I'll ink in the bullseye as well.  Kind of has a heavy grunge look to it.
Where did you get the design for the etch?
I drew it out in Photoshop.  If you need the artwork, let me know and I can send you the jpeg for etching.
Yes please, that would be great.
Sent you a pm for your email address.
Dragonfly
Quote from: bean on January 15, 2008, 04:58:51 PM
Its a volume knob.
I purposefully biased this fuzz just a bit low so it has a bit more "spit and snarl".  :)
Dragonfly
Quote from: niggez on January 15, 2008, 06:15:34 PM
thanks...
its basically a FF circuit with some tweaks and small alterations...as well as different transistors.
allmonochrome
Quote from: Dragonfly on January 15, 2008, 08:58:46 PM
thanks...
i noticed that it has a lot more resistors than a typical ff, any info on that?
Dragonfly
Quote from: allmonochrome on January 15, 2008, 10:05:17 PM
thanks...
I'll draw up a schematic in a couple days.  :)
allmonochrome
Quote from: Dragonfly on January 15, 2008, 10:29:36 PM
thanks...
nice nice, thanks a bunch  :)
~arph
Nifty way to wire the supply! If i understand correctly the GND of the board is connected to the enclosure though the output jack. And the GND from the battery is connected to the enclosure when the input is plugged in.
hairyandy
#4193
Quote from: ~arph on January 16, 2008, 04:00:38 AM
How else would you do it?  Wiring the battery ground to the input jack shield is how you turn the battery off when the pedal is unplugged.  I've been wiring my pedals just like that since I started years ago...
Andy
Andy Harrison
It's all about signal flow...
Hairyandy's Layout Gallery
~arph
Actually, I just realized I do it pretty much the same thing.. Only I wire the GND connection to the board at the input jack. So only one wire goes to the output jack.
Dragonfly
#4195
foxfire
i'm thinking you're just showing off now. crap that looks good both in and out.
niggez
Just finished building a 2x12 and my Orange Squeezer/Green Ringer. (Except for the corners on the cabinet and the paint on the pedal... i will put blue stripes on the pedal! And my MK-II/Fuzz Face only needs to be boxed up.
bean
Quote from: Dragonfly on January 16, 2008, 05:40:13 PM
SOUND SAMPLE
Very nice. I love flabby fuzz! I'm really curious about your swirly tech now! I like the buss wiring...do you find it to be pretty stable? I have some thin buss, but have stayed away from using it for routing.
Gila_Crisis
