Dave_B
Quote from: Ronsonic on February 15, 2008, 11:13:15 AMNice job on the Prophet 5, Gil.
Agreed.  You couldn't have picked a cooler synth to restore.  Now go play "Let's Go."   :)
Help build our Wiki!
Gil
#4521
Thanks !
Well, I would put such an effort restoring only high values synth. I have a few others here such as a Matrix 6 and Prophet 2000
which need repair, but I'm not going to spend too much time into them. I'd really like to find a dead CS80 though  :icon_eek:
BTW, I think my most favourite P5 tune of all times is really the solo part of PHD's "I won't let you down" ;)
http://www.youtube.com/watch?v=R5prT2qiiWY
gutsofgold
Its odd seing so many of you who have your power jacks sit below your input jacks. Doesn't seem right to me, or is this to allow for more room for the board on the inside?
darron
#4523
Quote from: gutsofgold on February 16, 2008, 06:48:34 AM
do you mean beside the input and not right up the top like on boss/ibanez etc.? the answer is pretty much yes. if you use the small MXR size boxes with a battery, then there's a logical layout which pretty much fits everything best. battery at the bottom, then switch above that, then the input/output jacks on above on the sides. now there's a gap on the left and right side of the switch where nothing else can really go. if there's room i like it right up the top, but the boxes are small and there often isn't. i agree, it doesn't seem right to me either. i don't like all that unshilded area right next to the audio and the switch. if you can use an un-insulated jack with reversed polarity (like the 3.5mm on EHX and the rat) and always have something plugged in there, it fixes that fear, but it's not practical for compatibility. if it's near the jack then i put it near the output since it has less prongs coming out and gives more room.
edit: ohh. and i forgot to mention that i usually like the pot and knobs to be as high as possible to get them away from the switch. you don't stomp on a switch as precise as you plug fast riffs.... if the power jack was there then it would take up a lot of space where the pots could be.
Sody54
My newest endeavor.  Don't have enough pedals to warrant a full pedalboard, so I decided to box up the 3 I use the most in one box.  This is one of the samples I recieved from one of the places mentioned here.  The box itself is plastic with an aluminum cover.  I was hoping that both would be thick enough to be useful for pedals, but it doesn't look like it's going to be so.  Should be fine for in the studio or practice room, but I don't think it'll last long gigging with it.
At any rate...
Matsumi SRV Special, Multifuzz is a multi face with a 3 position rotary changing between trannies (not built yet), and the Snake Eyed Beaver is a '77 Grey OD250 with a Gus Booster in front of it.  All artwork is done in Adobe Illustrator, printed on photo paper and glued to the cover.  Then shot with 3 coats of Krylon triple thick glaze.
I'll post gut shots when I get everything wired up and working.
jpm83
Here is a power supply board for tube cricket which I will be making in near future.
Janne
suprleed
Quote from: Sody54 on February 16, 2008, 01:34:23 PM
Cool idea!  You've made your own multieffects workstation.  I need to try the photo paper label method on one of my future pedals.  Yours look great!
AP
"That's the way I play" ~EC
Hamfist
I'm on a "function over form" kick lately.  No LED, battery only Dist + built on the Tonepad Microamp layout.  I used a 2n2 cap to ground at the input and a 2n2 across the diodes like the '77 DOD 250 because I like it so much.  So it's sort of a "greatest hits" compilation of the whole DOD 250/Distortion +/Ross Distortion thing.
deadspeaker
#4528
My 3rd stompbox will be a Sansamp GT2. It is mostly done. I don't have the pots or switches wired on yet, but all of the wires that need to be hooked to the board are in place. I've been slowly putting this think together since xmas time and now I'm getting close. Look at that mess of wire!
<img src="http://img20.imageshack.us/my.php?image=imgp0172rc7.jpg" alt="" border="0" />
hendrix2489
i still got to decal 8 more pedals that are finished, but here is one thats done.
DR.Boogie Pedal  6 pots and 4 trimmers ,that is 10 times the Fun :) WOO!   sorry for the bad pics, my camera is dead, had to use old crappy one
hers a fulltone 70
and a ds-1 that i keeley modded
kurtlives
A Vibro Champ in the works.
My DIY site:
www.pdfelectronics.com
Dragonfly
ambulancevoice
jakenold
Quote from: kurtlives on February 16, 2008, 10:26:36 PM
Which chassis are you using for this project?
I've been drawing up a cabinet for a Blackface Vibro Champ with a 12" speaker, and I'd like to check out what kind of chassis my fellow builders use.
Jake
greigoroth
Quote from: Dragonfly on February 16, 2008, 11:17:44 PM
Best looking pedal I have seen! Love the knobs and the swirl! What is it?
Built: GGG Green Ringer
Dragonfly
Quote from: greigoroth on February 17, 2008, 08:45:56 AM
Thanks... :)
heres a LONG sound sample...messing with the filter and gain knobs....
SUGARBUZZ SOUND SAMPLE
Timebutt
#4536
My god, that swirl is absolutely amazing ... the back side almost looks like marble  :icon_eek:
Truly great job!
Completed Projects: Gus Smalley Booster, Modded Russian Big Muff, Orange Squeezer, BYOC Vibrato, Phase 90
Dragonfly
Quote from: Timebutt on February 17, 2008, 10:25:10 AM
Truly great job!
I'm getting to the point where I'm starting to really get the technique refined for my use. Just takes a LOT of practice.
kurtlives
Quote from: jakenold on February 17, 2008, 07:32:13 AM
Jake
I bought it fromCeriatone, only $40 I believe.
My DIY site:
birt
http://www.last.fm/user/birt/
