Zben3129
Quote from: jpm83 on February 20, 2008, 06:04:31 AM
Quote from: GREEN FUZ on February 19, 2008, 05:20:38 PM
Quote from: jpm83 on February 19, 2008, 04:01:46 PM
Here is my transistor tester in a soap box.
And here is it's guts.
Janne
That was quick  ;D.It works then?
It works great. The red led flashes when D.U.T is good PNP and green when it's good NPN. I still have to find a bad tranny to check what it does in that case, but I'm 99.9% sure it works.
Janne
Hmmm...I can easily tell you how to make a bad transistor  :P
Anyways, I'd just torch one and put it in a pedal that has a socketed tranny
Zach
juse
Quote from: Fuzzy-Train on February 21, 2008, 11:22:34 PM
That's what I'm talking about. It's like it's daring you to stomp on it. Or it's hulking out on your board.
zeta55
My latest build, Dr.Boogey, a bit tight with 16mm alpha pots but possible.
/Krister
Visit my site: http://www.zeta-sound.se/
darron
Quote from: zeta55 on February 22, 2008, 07:36:08 AM
/Krister
that's how you get the job done! fantastic.
dschwartz
#4604
/Krister
:o  :o  :o  :o  :o   wow!!!!! that´s really nice! and you even put a battery in it...awesome!!!!!
Tubes are overrated!!
http://www.simplifieramp.com
Renegadrian
OMG, tell me it's not a 1590B... :icon_eek:
You should rename it "Dr. TETRIS" then... :icon_mrgreen:
zeta55
Quote from: Renegadrian on February 22, 2008, 08:01:24 AM
Yes, it's an eddystone 1590B size.
Dr.TETRIS, why not :icon_lol: :icon_mrgreen:
/Krister
suprleed
Quote from: zeta55 on February 22, 2008, 11:40:52 AM
/Krister
:o :o :o :o :o
6 knob Dr. Boogey in a 1590B!!!  I didn't think that was possible!
Well I'm eating some humble pie right now cause I can hardly fit a simple 2 knob boost/distortion into a 1590BB... :-\
"That's the way I play" ~EC
juse
Wow.... I'm in knob shock.
gijimmbo
I had to jump on the bandwagon too...
Here's my first attempt at the swirls just finished yesterday.  Green Ringer clone!!  i love this thing
rackham
/Krister
Go You!
That's properly inspiring stuff. 8)
tiges_ tendres
Quote from: gijimmbo on February 22, 2008, 01:25:20 PM
Nice Weiner! ;)
Try a little tenderness.
kurtlives
I had to go downstairs and check tht my doggy was still there. I have one that looks identical. Is yours a minature?
Nice swirling
My DIY site:
www.pdfelectronics.com
Renegadrian
#4614
Quote from: suprleed on February 22, 2008, 12:21:13 PM
/Krister
:o :o :o :o :o
I had to spend some extra time to fit a markm perf 250 grey spec with mods in a 1590B...There are 2 knobs as usual, 2 DPDT switches (Diode selection - Input cap selection) switch, battery, DC jack...I like the closed jacks, they seem somehow less obtrusive...I think this is a nice project and you should carefully study every component's position so to use the space at its best...
BTW, it is the PCB version, isn't it? which version? was this an easy build? did you use shielded wire for the signal? noises?
And - gijimmbo...Nice swirls!
12milluz
Quote from: kurtlives on February 22, 2008, 04:16:46 PM
Nice swirling
Mine looks the exact same too! And it is miniature. :D
nice job on the pedal too
Quote from: Processaurus
You need a glade plug-in, in on a footswitch.  Kick on the big muff, then hit the air freshener pedal.
Visit my site: http://www.freewebs.com/12milluzmusic
earthtonesaudio
gijimmbo
Hey thanks for the good words guys.  and actually, no.  she's not a minature, just a runt.  lol. ....
her name is 'molly' and she is THE coolest dog on the planet!!  ...only thing is I don't think she really appreciates the subtleties of the green ringer just yet.   ;)
zeta55
Quote from: Renegadrian on February 22, 2008, 07:57:37 PM
/Krister
:o :o :o :o :o
Yes, it's a PCB, I used the Eagle files from http://gaussmarkov.net/wordpress/circuits/dr-boogey/ and adjusted the board layout to suit my needs.
Easy build? The difficult part was the layout of pots, jacks and stuff on the enclosure.
It's a bit noisy, but for a high gain circuit like this it's fine, I used no shielded wires.
/Krister
Morocotopo
LHX2 Fender amp simulator. Many hours of planning the pedal layout to fit in a reasonably small box! Added 3 band EQ at the end, power tranny inside the box.
Here you can see the internals. I made a "shelf" attached with the outside handles screws to put the PCB´s on. I also made a "shielding sub box" for the power tranny and regulator PCB to avoid getting AC hum/noise into the signal. Seems to work well, no hum at all. A real mess of wiring, shielded wire EVERYWHERE!  ;D
Backside, I added an FX loop to insert processors between the amp sim and speaker sim.
Morocotopo
Morocotopo
