ambulancevoice
how come you never do gut shots dano?
dano12
Quote from: ambulancevoice on May 12, 2008, 03:36:00 PM
Usually because I get it all boxed up to play with it, then move on to the next project before getting full pics :)
I'll try to be better.  :icon_mrgreen:
Beros
Quote from: dano12 on May 12, 2008, 03:06:59 PM
Smokey amp with increased gain, voltage sag and a cheap chinese meter:
Best name ever.
Man ska inte ligga med lik
cpnyc23
Hey dano
how did you cut the hole for the VU?
I've always wanted to things like add large holes covered with semi-opaque plexi and lit from behind with various color LED's for no practical reason at all... only problem, is i've never known how to properly cut a circle larger than what my unibit can do (which isn't all that big).
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
jakehop
Chris, you can use those cheapo wood drilling saws (for the lack of a better word) that can be mounted to a drill. Those work OK for me on aluminum, but will of course wear out. But they aren't all that expensive. If you wanna do it right, buy the ones made for metal. I've got one I use for tube-holes, and it's awesome!
mfg Jake
andrew_k
Quote from: dano12 on May 12, 2008, 03:37:33 PM
:P
dano12
Quote from: andrew_k on May 12, 2008, 06:49:11 PM
:P
Yep, that pretty much sums it up. :)
dano12
Quote from: cpnyc23 on May 12, 2008, 05:59:50 PM
Hey dano
-chris
I drilled a hole and then used a nibbler to cut out the circle. It was nibbler hell. My hands are still sore.
I guess a dremel with a cutoff bit would be better.
Fuzzy-Train
LMAO at the name.
THERE IS NO SIG.
The user formerly known as NoNothing.
Stuff I built!
http://s174.photobucket.com/albums/w106/Cpt_sergeant/?start=allRandom
Hanglow
You can also use hole saw drill bits like this on aluminium etc.
kawayanstrat
cpnyc23
what are those little flecks of silver in the swirl?  ???
-chris
Papa_lazerous
Quote from: cpnyc23 on May 13, 2008, 06:03:35 PM
-chris
my guess is the flash reflecting off of defects in the finish of the clear coat ;)
nice swirl though I like the colours
caress
some new stuff, sorry about the huge images...
a noiseswash.  for anyone into weird sounds, feedback mysteries and sonic mayhem, this is a must build.  it would be right at home in a modular synth as a wave animator of sorts... i only really tested it with a sine wave and it was amazing-ly out of control.  there are some beautiful textures there for sure...
and a not-so-great shot of my vss30 (dirty socks down there!).  i built a wooly mammoth and boxed it in there along with a six-pole active lpf utilizing a max1044 charge pump.  i'm happy - no more plugging into a fuzz.  (such a ghetto drilling job to fit that big switch on the left... but it works well and i've been touring with it!)
caress
MXR Distortion+
Switchable clipping: 1n4148's or red LED's.
With a ghostly MXR image!
kawayanstrat
-chris
Those are blue metal flakes. ;D
Dragonfly
Once I get back from visiting family in a week, this hideously ugly box will be housing a "no controls" fuzz similar to a Orange Sunshine. Heck, I might just make a stock OS...what horrible (yet great) sounding beasts they are....
Just a switch, 2 jacks, power, and LED...
This box is somehow "fitting" to that particular circuit.
Boogdish
Quote from: caress on May 13, 2008, 07:16:53 PM
could you point us to a schematic or layout of this?
