Renegadrian
armstrom and focalized - nice pedals!!! Great work, hope they sound as good as they look!!!  :icon_wink:
Dimebugg, tell me something more about that Tobias thing...Layout-components-sound...
Focalized
Quote from: Renegadrian on May 27, 2008, 05:08:54 AM
They all sound different! There is no perfect Fuzz.
ambulancevoice
Quote from: Dragonfly on May 26, 2008, 06:48:44 PM
Quote from: foxfire on May 26, 2008, 06:47:21 PM
Quote from: Dragonfly on May 26, 2008, 05:53:16 PM
Yeah...I had this box offered in the "for sale" forum, but I decided to build in it !  :)
Basically it's a modded version of Hemmo's Buzz Box ...texture knob to control the splatty octave...and volume...BC108's....blah, blah, blah....
It sounds like THIS !
so how well do you know the band Dixie Witch? rylan
I've seen them play, but I don't know them. Great live band. I should probably get a CD or two of theirs, but I never got around to it.
Why ?
wow, never thought a buzz box could sound like that
and dixie witch are great to, cant remember what album ive got, but damn good shit
armstrom
Quote from: Focalized on May 27, 2008, 12:11:12 AM
If you put a black border around where you would cut the decals, it would hide the decal edge. Fill out the design some. Something to try. If you do a full face, make sure you test it to line everything up.
Thanks for the tip. With regard to having everything line up I would probably include a little hole-center circle on the decal. Then I can just apply the decal to the undrilled enclosure, clear coat it and then drill the holes using the spots on the decal as a guide. I would probably put matching dots on the enclosure to help align the decal. Drilling through the decal once it's fully sealed in clear coat shouldn't pose a problem.
-Matt
DimebuGG
I found a schematic on the net ago(I forgot the site). Since I 'm curios of active basses, I made a layout on that schematic immediately.
I'm no electronic-wiz but this schem has a Baxandall type EQ on it and is using NJM062D(i'm using TL062CN on my prototype).
I like the sound of this circuit equally or more than the tillman jfet preamp IMO..
tdavid76
I would just like to add that the GGG EQ works great...I built two last year (the 5band + Gain stage version)  to run as the preamp sections of a stereo TD20x0 amp (also from the GGG site).  Put the whole thing in a rackmount enclosure...worked out beautifully...at least I'm quite pleased.
Renegadrian
All right, Dime...Mind to share your layout?! post it here or in the gallery?  :icon_wink:
DimebuGG
I'll find time posting it since it is a PCB Artist file.. :icon_biggrin:
Dragonfly
Quote from: DimebuGG on May 27, 2008, 09:14:43 AM
You could always just take a "screen shot", open up Paint (on a PC) and press "paste", and edit from there...just save it as a JPEG or GIF. Should only take a minute or two.
DimebuGG
Quote from: Dragonfly on May 27, 2008, 09:19:11 AM
already tried it..tracks happened to be always at the top of the pads...i'm not using a multi-layered or multi-colored one..sorry...i'm a newbie in this software..:D :D
kawayanstrat
Quote from: DimebuGG on May 27, 2008, 09:37:17 AM
Mukhang ayaw mo mag-share a. ;D
Dragonfly
it was worth a shot :)
ubersam
Quote from: tehfunk on May 24, 2008, 02:37:36 AM
Second build, MXR Micro Amp, on smallest smallbear perfboard...
that is one HUGE resistor you got there  :icon_eek:
tehfunk
Quote from: ubersam on May 27, 2008, 03:37:58 PM
lol, yeah, and I fit it in three spaces to try and make everything neater to solder on the underside. its 22m and i made a mistake when i ordered it from mouser/maybe it was the only wattage they had of it and i didnt realize how big it'd be.
Carvin CT6M > diystompboxes.com > JCM800 4010
The tools of the artist give you a chance to twist and bend the laws of nature and to cut-up and reshape the fabric of reality - John Frusciante
Dragonfly
Quote from: tehfunk on May 27, 2008, 06:32:26 PM
Just so you know for the future:
That resistor doesn't "have" to be a 22M. It can be anything above a 1M, though the higher the value, the better. Whatever is available in the highest value will work fine. In fact, using a lower value can bleed off a bit of the "brightness" that is inherent to the Micro Amp that some people don't like.
DimebuGG
#5775
Quote from: kawayanstrat on May 27, 2008, 02:19:08 PM
Mukhang interesado ka rin bro ah.. :D :D
1B,2B,3B is the treble pot(CCW,W,CW). The 330pF cap between lugs 3B & 1B is offboard as well as the 0.022uF at the bass CW &CCW lugs. I think there should be a 12K resistor between pin 1 of the opamp to the CW lug of VR4, not sure though... :D
REGNAD
letsgocoyote
Heavily modified DOD 440 clone
http://www.youtube.com/watch?v=OHX_9iPXwVY
i wanted to do a run of these, but lfo ticking changed my mind.  i have since added a toggleable buffer, which takes care of most of the lfo ticking, enough that it will happily be staying on my pedal board.
im going to make a post and share how I built it.
Tuemmueh
Quote from: letsgocoyote on May 27, 2008, 11:24:49 PM
Great sounds here! I'm totally looking forward for the details of how you built it!
cpnyc23
Wow - the MEEP is tops!
Can't wait to get more info...
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
