yeeshkul
Here is my recent Maestro FZ-1S clone
fuzzo
nice like the original :icon_biggrin: , but as big as an EHX pedal ;D
GREEN FUZ
AAAAARRGGH!!! IT`S HAPPENED AGAIN.
I`m in the middle of building an FZ-1s with a design based on the original. I`m using a smaller enclosure though so I`ve had to redefine the graphics a bit.
Yours looks great BTW.
Sweetalk
Where do you get those knobs yeeskul?, I have an old acoustic guitar with those knobs and one it's broken. Great build!
DougH
AstroTone Fuzz.
I made it out of a 4" PVC drain cap:
armstrom
Well, it's not exactly a stomp box, but I thought I would share my latest creation. This is my first attempt at building an amp. It was built for a harp player who's nickname is "The Hurricane" (hence the name of the amp).
Here are the details:
  • LM386 based preamp (based on the Ruby and Noisy Cricket designs)
  • Big Muff tone control between preamp and power amp stage
  • TDA2005 Power amp
  • 12V 2A power brick supply
  • Ted Weber Signature Series 6" speaker
  • Custom wooden cabinet and aluminum chassis
Here's a sound clip a friend recorded for me. Fair warning, it's about 2.5MB.
http://www.mr2-power.com/Hurricane_test_2.mp3
yeeshkul
Quote from: Sweetalk on October 22, 2008, 07:39:21 AM
local shop, if you are desperate i would send you one next time i go there :)
kierc
My first enclosure! taken a while, but I'm pleased with it  ;D
Thanks to Nelson's Clone Theory project, and MarkM's enclosure etching tutorial  8)
Gila_Crisis
really cool your Clone Theory!
i'm building one too!!!  how does it sound?
kierc
Cheers Gila_Crisis  ;D
Sounds wooshy and crazy!! haha
Mine has a deep hum (pretty sure its my power supply though), but I recorded a rubbish sample of it (from my camera, and my playing leaves ALOT to the imagination!! - I only recorded this to capture the back noise..) which you can see here : http://www.kierc.co.uk/clonetheory/theorysamples.html
I'm pretty sure if I knew how to play guitar then it would be a good effect, so I'm sure you'll like yours  8)  (also, I don't know if he has updated it since, but the regulator was backwards on the layout, so double check  :))
Dragonfly
Quote from: yeeshkul on October 22, 2008, 06:09:48 AM
Beautiful !
Absolutely flawless work !
yeeshkul
Thanks Dragonfly :). I love your hippie-style painting on the boxes. That black&yellow looked so much like early Pink Floyd oil-frame projections ...
Dragonfly
Quote from: DougH on October 22, 2008, 07:40:41 AM
AstroTone Fuzz.
;D
you should look into the spray magnetic shielding paint for the interior
i recognize a few things about your build ...switch wiring, etc...
i dig the decal too -
you bust out all your Marc Bolan riffs yet ?
DougH
Thanks. I read some articles about spray shielding and etc and came to the conclusion that foil would probably be more effective and I already had it. It was pretty easy, just cut it into strips, used spray adhesive and criss-crossed them.
The sticker artwork is from a Hubble photo.
No Marc Bolan for me but I have been playing some Tommy Bolin with it. :icon_wink:
deaconque
AstroTone Fuzz.
Hey Doug, what did you use for the bottom of that PVC enclosure.  Looks great by the way
DougH
#7435
I'll take a photo of the lid tonight. I forgot about that... Basically I used a 4" PVC drain grate. It's the actual drain part with the slats and openings on it. It has a sleeve that fits right into the cap, with a flanged end. The sleeve was a little too long (would extend into the box too far and interfere with the jacks) so I used a hack saw to trim it down. Then I screwed a 4" lid for a plastic electrical box to that for the actual lid and put rubber feet over the screws. I covered the inside with foil. I used 4 screws on the sides of the box (PVC cap) to hold the lid on. I didn't make provision for a battery, just used a DC jack, so no need to get inside (except to take photos  :icon_wink:).
This enclosure was basically an exercise in "What can I find at Lowes?" and cost about $3-$4.
John Lyons
Viva drain pipe caps!
These are ABS plastic.
They are about three times the thickness of the white one Doug used above.
Also taller. I cut it down and had to recess the jacks and pots since the box is so thick.
Foil shielding looks like poo but it's a lot better than spray on since it's much thicker.
You can get a roll of aluminum foil tape for $6 at lowes ( I use a lot of it...)
I sanded and polished these. Lotsa work there :(
Nods to Jack Orman for his use of these (white ones) and pics of them on the AMZ site
John
Basic Audio Pedals
www.basicaudio.net/
nelson
Quote from: kierc on October 22, 2008, 11:00:37 AM
Nice work!
Love the blue board.
I should probably build it myself again. I don't have mine anymore.
My project site
Winner of Mar 2009 FX-X
Gila_Crisis
Quote from: kierc on October 22, 2008, 12:07:07 PM
it's horrible the hum, btw the churus/vibrato effect sounds really fine! maybe on mine i'll add the double track switch too.
kierc
Quote from: Gila_Crisis on October 22, 2008, 05:41:25 PM
What does the double track mod do? also, how do you do it? as Nelson says the mods are incorrect?
