Sweetalk
Thanks a lot!!!! :icon_biggrin: :icon_biggrin:.... You can buy the adhesive paper from Small Bear, but isn't the same that I used. It has to be the same with any adhesive decal paper...
It's hard to match the color in the screen to the printer so I use the printer color as the base... I use transparent layers to have a better color reference, not white background. I use ink jet but if you use color laser the results has to be better, you only have to buy the correct adhesive paper.
bent
are you talking about the water-slide decal paper? ???
bent
Long live the music.....
Sweetalk
Quoteare you talking about the water-slide decal paper?
Yes... Here is known as adhesive transparency or transparent adhesive paper...
nordine
here, a MXR phase 45, with some of jc maillet mods.... external bias pot, named 'color'
zerohero
Quote from: nordine on November 17, 2006, 11:37:39 PM
just... awesome... how did you paint that
jonathan perez
just some drop in builds...showing off the gooooods. THANX NATE AKA $UPERPUMA FOR THE BOARDS!
my pride and joy...
no longer the battle of midway...(i left that band)...
i hate signatures with gear lists/crap for sale....
i am a wah pervert...ask away...
nordine
Quote from: zerohero on November 18, 2006, 12:07:01 AM
hey thanks
well the process was something like this:
-wet sanding (from grain 100 to 600)
-then about 3 or 4 coats of spray
-then used acrylic paint (red and black) for the graphics
-and, last, sprayed three coats of acrylic lacquer, so it shines
letting each layer of material (being spray paint, acrylic paint or lacquer) dry enough time helps a lot for a clean finish, i've learned
darron
nordine, that's right up there with some of the BEST DIY boxes that I have ever seen! it's because of talented people like you that i love to browse this forum!
seeing such detailed hand work like that makes me feel like having some stamps made up, or something!
Izzy
Where did you get those transistor sockets from? I like it!
Sweetalk
Awesome job with the paint nordine, congratulations!!
coffyrock
nordine...
2 words: AWE. SOME. :o
looks like orange base coat with red/black graphics? maybe just looks orange in the pic?
Built so far: ROG Ruby, matching pair of LPB2s, Mr. Clean, Easy Drive,
Next up: Bazz Fuss, ROG Grace Overdrive, Smashdrive.
zeta55
Here's my latest one, Ross compressor.
/Krister
Visit my site: http://www.zeta-sound.se/
$uperpuma
that guy is a little grumpy :) Hope he compresses well!
Breadboards are as invaluable as underwear - and also need changed... -R.G.
Fuzzy-Train
thebattleofmidway your boards look like candy.  :icon_biggrin: Looks great.
THERE IS NO SIG.
The user formerly known as NoNothing.
Stuff I built!
http://s174.photobucket.com/albums/w106/Cpt_sergeant/?start=allRandom
zeta55
Quote from: $uperpuma on November 18, 2006, 03:46:33 PM
Yes, I found out that the circuit would not sound as compressed as I want without him    :icon_eek:
/Krister
$uperpuma
Quote from: zeta55 on November 18, 2006, 04:03:48 PM
/Krister
:D
jonathan perez
Quote from: NoNothing on November 18, 2006, 03:51:58 PM
well, i do eat a healthy dose of gummi life savers as i build...
nordine
#1397
hey folks, i'm flattered  :icon_redface:
thanks for the kind words, it indeed did take some time.. seems, it delivered what it took  :icon_biggrin:
as for coffyrock question, i'm starting to doubt the trueness of every photo i've looked at in my life, because, carefully looking the pedal -then the photo-, you can tell these ARE NOT the original colors ...the red is a sparkling red, the black shines its texture because of the lacquer, the orange is *not that* yellow
here, another take:
PeterJ
Here's my first active build: The Fetzer Valve (I've build a basic A-B box before, never something powered):
Inside (sorrry, a little fuzzy):
Thanks to Aron (my source for the 3dpt) for hosting the forum and everyone who shared ideas!
Peter
Duct tape and particle board!
royzic
#1399
amazing work everybody!
you guys set a very high standard.
here is my take on aluminum bent boxes.
http://www.esnips.com/web/greenhouse-effects/
(sorry,couldn't put the picture directly on my post)
roy
