SonicVI
That's just a temporary box. I don't have the permantnent one done yet. However, the Blue Box will be turning into a Purple Box.
JoeGuitar
Everyone needs one of these.  :icon_wink:
Joe
SonicVI
Ok, I might stick with blue for the Blue Box clone, but the paint doesn't seem very durable, it's kinda soft, so I may need to redo it. I need some MXRish knobs too.
QSQCaito
Quote from: JoeGuitar on August 11, 2007, 04:24:31 PM
Joe
Pretty :D
Is the golden part marker-painted?
D.A.C
JoeGuitar
Quote from: QSQCaito on August 11, 2007, 06:50:52 PM
Pretty :D
Yep - a Pilot Gold Marker.  Krylon makes a marker called "18Kt. Gold Leafing Pen" that turns out a lot nicer; but the tip is huge & it takes more patience than I have to color in the lines...........
JOe
Traintrack
It has all the mods plus I used the A/B switches to swap the caps on C5 and C6 as per a conversation with Paul C.
I would do it different next time with a larger board to hold the clipping section. Also I would use a rotary dial instead of toggles.
I love this pedal. I can get so many different tones with it.
I started this one almost two years ago! I am trying to clean up my mess. I still need to get some nicer washers on the switches.
Hiwatt25
Quote from: rhys on August 10, 2007, 02:49:16 PM
FSH-1
Is someone a fan of Spacemen Three?  That looks like the cover of the Perfect Prescription album.
nightingale
Quote from: Hiwatt25 on August 12, 2007, 03:25:53 PM
I am!
I have heard that Sonic-Boom is into some pedal/synth diy too?
best,
ry
be well,
ryanS
www.moccasinmusic.com
JoeGuitar
Here's my Highway 89.  This pedal ROCKS!!!!!!!!!!!!!
The switch is there to knock some of the highs off if desired.
I don't know which I like better, the BSIAB or this one.   :o
Joe
Shakal
Very clean white painting!
How did you make the black parts?
JoeGuitar
Quote from: Shakal on August 12, 2007, 07:04:13 PM
The black is done with decals.
Joe
letsgocoyote
bazz fuss with gain control
heres a sound sample:
http://www.letsgocoyote.com/fuzzboxsample.mp3
ambulancevoice
how did you do your gain pot?
do you have a schem you used?
carrejans
#3093
Great sound, except some pops, not always. I should rewire the whole thing; cause it looks like hell inside. In the future I will not wire everything when it's outside the box; and use not so stiff wires.
Not a great finish; none actually; but I like it. Sometime in the future I will try to etch enclosures.
Dave_B
Quote from: JoeGuitar on August 12, 2007, 07:17:54 PM
It looks fantastic.  Can you see the edges of the decals?  Just curious.
Help build our Wiki!
letsgocoyote
Quote from: ambulancevoice on August 13, 2007, 01:41:17 AM
i used a 1k pot that connects from the emitter of the transistor to ground. lug 1 of the gain pot is connected to lug 2.  thats it, seems to work pretty well.
basically the exact same way the 'Dirt' control is wired in this bazz fusss version:
JoeGuitar
Quote from: Dave_B on August 13, 2007, 01:40:23 PM
Thanks - yeah, you can see the edges.
Joe
JoeGuitar
Here's a Red Llama I just finished for my brother in law.
I painted this thing 4 times before it turned out right.  Then when I went to put it together I couldn't fit the circuit board in.  :icon_eek:  So I ended up making a new layout with a cut out for the power plug.   ;D  I'm glad this one is done.....
Joe
hendrix2489
great looking projects , hey JoeGuitar that  waterslide looks awesome :o
choklitlove
a few of my latest -
Crackle Book
more info and a video: http://geocities.com/worthekik/cracklebook.html
Atari Punk Capsule
more info and a video: http://geocities.com/worthekik/apcapsule.html
Hysteresis Oscillator
more info: http://geocities.com/worthekik/hysteresisbuild.html
Jen HF Modulator
more info: http://geocities.com/worthekik/jenhf.html
sometimes i don't feel like wiring a switch.
my band.                    my DIY page.                    my solo music.
