Michael Allen
you might try these jacks on ebay:
http://cgi.ebay.com/100-Main-DC-POWER-PANEL-2-1mm-JACK-for-Boss-Pedal-PJ9_W0QQitemZ120274934943QQihZ002QQcategoryZ73134QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They're 2.1mm with switching and the jack itself protrudes from the pedal. With this one, you could insert it into the enclosure, tighten the nut on the outside and all that is on the inside is that small (~2mm) flange with the contacts. This looks like it could easily fit between the enclosure wall and the pots if there's not enough vertical space above the pots. I bot a lot of these of ebay and have loved using them. I hate the internal nut even though the jack is flush. don't like redoing wiring every time i take something out.
railhead
NICE! I just bought me a load of them -- now I have to try and hunt down a US supplier...
Quote from: railhead on June 23, 2008, 02:11:45 PM
If you're anywhere near Toronto you can get them at Honson Computer.
dave
Renegadrian
Quote from: fuzzo on June 23, 2008, 02:04:06 PM
I've this stuff :
I don't know what I can put in  ???
Prof. Tweed? Thor? boutique fuzz? these are just the first 4-pot-fx to come in my mind...
ubersam
Quote from: railhead on June 22, 2008, 05:56:58 PM...I mis-measured some of the hookup wire, so try and ignore the extra cable length -- and the snafu with the LED...
What are you talking about? It looks damn pretty to me... nice layout too...
fuzzo
Quote from: Renegadrian on June 23, 2008, 03:36:12 PM
yes 4 knobs or knobs + switches. There's also a hole to jack remote.
birt
Quote from: Michael Allen on June 23, 2008, 02:04:58 PM
i tighten it when i install it and then melt the nut to the jack on one point so it never gets loose.
http://www.last.fm/user/birt/
visit http://www.effectsdatabase.com for info on (allmost) every effect in the world!
dominatrix_volleyball
Quote from: dschwartz on June 23, 2008, 10:11:51 AM
This is the "nazca pets", half tremulus lune, half phase 90, with a "mix lfo" switch
a pair of soundclips:
http://diynoise.googlepages.com/phase-trem.mp3
http://diynoise.googlepages.com/mix_lfo.mp3
I'd be *very* interested in knowing how this works.
letsgocoyote
I built this today:
its small, about 2.25" x 3.25" its the smallest hammond 1411 enclosure
cork feet are neat and no more expensive than th eplastic ones.  i had to relocate the screw holes though because the old ones were blocked by the battery and audio jacks
guts!
circuit is electra distortion with the emitter resistor omitted for more gain.
cpnyc23
Is that enclosure aluminum or steel?  If it is aluminum, is it the same thickness as the other 1590 enclosures or thinner? It looks pretty cool
-chris
"I've traveled the world and never seen a statue of a critic."    -  Leonard Bernstein
letsgocoyote
its aluminum.  i think its hammond 1411c.  bit thinner than the 1590 series, also a bit softer, so it all drills very very easily!  but its still very very sturdy (partly due to the small size).
they are quite cheap.  i bought a grey coated one because it was all that was in stock for $6 from digikey, but the plain aluminum ones, when availbe are only abotu $4, and much cheaper in quanity
Quote from: frequencycentral on June 23, 2008, 05:51:00 PM
Discussed in this thread: http://www.diystompboxes.com/smfforum/index.php?topic=68693.msg549539#msg549539
Much thanks.
I also like your idea in the thread. When you think everything's been thought of, somebody makes a ring mod an LFO.
John Lyons
#6073
Black Walnut "Dr Boogie".
"Skyripper" in Oak
Death By Audio "Fuzz War" rehoused in Canary wood
john
Basic Audio Pedals
www.basicaudio.net/
andrew_k
I'm afraid to even ask what you charge for those wood enclosures... they look so incredible John!
WLTerry
Hola Daniel!!
This is definitely one of your bests works alongside of the Dual Rectal series and many others. It really sounds lovely an looks awesome... but the most important thing is the whole concept of mix the LFO to create something new. Congrats for your new "son".
Only one thing, if may I correct you in something small: If I recall from school and from my trip to Nazca many years ago, the cat is actually "the dog". Looks like there's a concensus about the names and meanings of the lines, check this out:
http://commons.wikimedia.org/wiki/Image:Nazca-lineas-perro-c01.jpg
De todas formas es un excelente trabajo... good job!!
WL
ambulancevoice
hey fuzzo, is that sasha grey in your display picture?
Michael Allen
Quote from: John Lyons on June 24, 2008, 12:08:29 AM
"Skyripper" in Oak
john
UNREAL! Those are the most beautiful pedals I've ever seen. forget graphics and paint. well done!
Processaurus
Hey John, have you ever considered making a boss type footswitch with your wooden style?  Like a big wooden block on some nice hinges, with a spring underneath, that pivots and presses a hidden switch?
By the way I love the way those knobs look with your enclosure, reminds me of old cathedral radios and ancient military radios.  And peanut butter cups.
ambulancevoice
John, a wood question, what wood has really dark or prominent figures or grain
and have you ever done a burnt wood finish???
