comfortably_numb
Yes, I've read the tutorial.
liddokun
Sorry if I sounded like a "know it all" there then, I hadn't realized this.
To those about to rock, we salute you.
liddokun
#6822
Anyways, I haven't contributed to this thread in a long time.  Here's my latest builds, AMZ Mosfet boost (orange) and TS 808 (obviously the green one  :icon_mrgreen: )
And here's the guts.
Don't mind the "epic fx" at the bottom, I put these on as a "signature", I'm not trying to take credit for the design of these pedals.  Just signature so that people know I built the pedal.  I don't sell them either.
gutsofgold
I like them both man! I love seeing thicker gauge wire in pedals...
Any mods on the screamer?
liddokun
Nope, no mods.  I built both as a favour to a friend, and he request the screamer to be stock.  Otherwise, I would have thrown in a few keeley mods myself.  The thicker gauge wire adds a little mojo to the pedals  :icon_mrgreen:
It's "vintage" wire, pulled from a 60's console tube stereo unit.  Just doing my part to stay green.
liddokun
I really like those little tube pedals, I've got to build me one.  The holes you put in for ventilation are really cleanly cut too. Great job!
Quote from: liddokun on August 29, 2008, 11:51:14 AM
Just a couple of hand files and a little patience..................they are very neccesary though - the big light blue resistors (2 x 10 ohm +/-5% 3 watt in series with the tube heater - to give the heater 6.3 volts from 12 volt supply) on the left get even hotter than the tube!
liddokun
Wow...that's pretty hot.  Vibracaster is a tube tremolo, correct?  What tube does it use?
Quote from: liddokun on August 29, 2008, 12:11:21 PM
Yup tube tremolo. It's a 6111 tube: http://www.diystompboxes.com/smfforum/index.php?topic=70160.0
..........but it could be built using a 12AU7 if you don't want 'compact' ...............and 'HOT'!
liddokun
Yes, IIRC, I read the beginning of the that thread, however I didn't get to the part with the new 6111 schematic. I was just assuming the 12AU7 because it's based on the valvecaster, which I should build as well.
Quote from: liddokun on August 29, 2008, 12:24:51 PM
You could just build the Valvecaster with the Vibracaster oscillator as an add-on - just one tube and five knobs.
'Gain'....'Tone'....'Speed'....'Depth'....'Volume'
With 'Depth' at minimum it works just the same as a 'stock' Valvecaster.
Franky
The ventilation holes are very clean!
Where do you get those ribbon german-flag-like? Do you make them yourself by gluing some cables together?
42
Quote from: Franky on August 29, 2008, 01:46:17 PM
It's actually ten way cable - ten different colours. I bought a load years ago - I'm just getting to the end of it. The supplier I used no longer stocks it - I saw some on Ebay a while back though.
carrejans
#6834
Here is my first etch. It's a reverse etch.
The booster is for a friend; his band is called "Fallen".
Insanekane
#6835
That reverse-etch is more difficult to paint.
Rebote, my way  ;D
cheeb
That reverse etch looks great, Jan.
JFX09
Sure does, i'm a bit envious of the depth you obtained.
Happiness is a effin' hot soldering iron
kurtlives
Trotsky!
I was quite happy with my decals.. In Soviet Russia Pedal Stomps You, Grit, Amplitude, Music Maker (input), Sound Box (output).
Yikes... I was into the mentallity of "Getter er done while building this one"
Tried a bunch of different transistors in this one... In the end I grabbed a metal can from my bag of random but cool looking transistors. It is labelled NTE 123A 044L..... It has a hFE of 150. It was the nicest I thought and made the grit control the most effective.
My DIY site:
www.pdfelectronics.com
ConanB
Built for a friend's bday, his nickname is Jebus...
First time using a decal. Only inkjet printer I could get access to wasn't as good quality as I had hoped, so Jesus' hair got a little streaky.
