g.
paperphoto and common grit sandpaper. just wanted something that looks already old...
DavidRavenMoon
Quote from: g. on January 12, 2009, 10:10:24 AM
EDP Wasp filter Clone (stand alone synth filter)
fuzz factor (germanium fuzz)
Wow, those cases are amazing!  I could do without the two tone knobs on the second one though.
SGD Lutherie
Hand wound pickups, and electronics.
www.sgd-lutherie.com
www.myspace.com/davidschwab
railhead
Quote from: g. on January 13, 2009, 03:03:45 PM
Do you mean inkjet photopaper? You just printed it black and white, reversed, and ironed it on?
g.
QuoteDo you mean inkjet photopaper? You just printed it black and white, reversed, and ironed it on?
yes but print with a laser printer
Fuzz Aldryn
Quote from: g. on January 14, 2009, 09:14:17 AM
... or a even cheaper solution is to print with a laser printer on sites of a catalogue. Got pretty decent results using this kind of paper - and I tried several ones! The catalogue sites turned out to be by far the best, as the paper peels off of the surface nearly by itself when you put the enclosure into the water adter you ironed it and it costs nothing.
If  had a photobucket account I would show some of my work but I haven't.
Regards
Helge
The French connection
Quote from: Fuzz Aldryn on January 14, 2009, 09:46:45 AM
Regards
Helge
Go on, it's free...you'll need one sooner or later  ;)
http://photobucket.com/
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Fuzz Aldryn
#8246
Ok, here we go!
HAO Rustdriver Clone. The smaller the better.;)
ethed enclosure for my Shinei SuperFuzz clone
ready SuperFuzz
sans mots:
Kosmos Phaser  a.k.a. Phase 90
OCD
sans mots:
Regards
Helge
g.
Fuzz Aldryn
Quote from: g. on January 14, 2009, 12:09:58 PM
great !
Thx! :)
A few more pics though not realy a stompbox but I guess you'll know what is.:)
jalien21
that purple battery looks really great in there, imho
Awesome, work! This tell me that you've been lurking so much catalogue... Hope it was not all IKEA stuff! :P
Dan
My picture files:
Fuzz Aldryn
Quote from: The French connection on January 14, 2009, 01:37:05 PM
Dan
Thanks! Mostly I use the free Quelle catalogue that my room mate always gets:D It has about 1600 pages. So I Still use the first one. Should reech a life time even if you take it as PnP paper for your PCBs. Also it works most of the time at least on the second try.:D
Regards
Helge
Valoosj
Obviously Copied Drive
Quote from: frequencycentral
Quote from: Scruffie
Zen
Regards
Helge
it doesn't seem like that should work, but it is awesome!
this should be filed under the "green initiative" since it is sorta recycling paper
would be nice to use this printing method on a pedal made from parts reclaimed from busted compact-florecent bulbs :)
ForcedFire
Fuzz Aldryn, that Squeezer rules. I can't get paint to stay in a big etched square like that when I'm sanding. Awesome pedals!
flo
All those etches are beautifull!  8)
orangetones
Quote from: Zen on January 14, 2009, 05:30:27 PM
Regards
Helge
Again, I agree.  paper from a catalogue is the best and a very green solution.  I have never had problems and from what is sounds like, there are some difficulties soaking photo paper off.  Catalogue paper comes off really easily!  I just tape a piece of it over where the board will print on a regular piece of white paper (just the way many do with small cut pieces of PnP Blue).
I just have to try it now with an etched enclosure!
Fuzz Aldryn
#8257
Quote from: ForcedFire on January 14, 2009, 06:28:07 PM
Thanks!:)
Don't know if I got you right, but you have to sand and polish before you start etching. This way the nonetched parts stay highgloss after the process which you will need in the further step.  Tap with acrylic paint (and that's important, because acrylic paint sticks pretty good on the etched areas but pretty poor on the polished surface) the parts you want to have to be painted (the etched areas in this case). Don't care if something of the nonetched parts are painted too, because they are high glossy. You can easily rub or wipe the excess away with a q-tip (for the letters) or a small piece of fabric. Doing this you don't touch the painted areas that much and the paint should stay in place. Now you can easily fix it with a clear lacquer of your choice. VoilĂ ! C'etait tous!
Hope this was some kind of helpful!
Regards
Helge
Fuzz Aldryn
#8258
Regards
Helge
Nah, believe me it works perfectly well. This kind of a "green initiativ" we've been doing already for a long time here in old europe.;) :D Don't have a catalogue by the hand? Watch your mailbox if you got some of the always annoying promotional brochures in there. They also work for this method. Not that well as catalogue pages but should be enough for making a simple pcb.:)
Regards
Helge
Edit: here's a pic of what I#ve been talking about:)
earthtonesaudio
I really like that idea.  A good way to recycle junk mail, and saves money on special paper too!
But how do you get it to go through the printer without problems?  Cut it to the standard paper sheet size before you print?
If someone has a photoessay or tutorial, I'd love to see it (in it's own thread of course).
