Hanglow
Bottom on a Klon I take it?  ;D  Nice box for that one
m-theory
QuoteBottom on a Klon I take it?    Nice box for that one
Yes.  I made that one for a buddy, because he's given me some great deals on gear over the past couple years, and let me borrow an amp of his for several months.  I believe the box is a 1790NS.  It's rather large, but that extra space allows for a nice neat layout, rather than just having to cram everything into a 1590B.
deaconque
cloudscapes
made a video of that waveshaper I made a few days back
http://www.youtube.com/watch?v=o-lxVIeZybA
{DIY blog}
{www.dronecloud.org}
Valoosj
Guess what this is ...
Quote from: frequencycentral
Quote from: Scruffie
danielzink
Valoosj
It's not fair, since you already know!
I did have to 'add' some traces to my original tiny layout. I forgot a few during downscaling.
My micro delay will have the same issue, as did my micro phaser and micro trem  :icon_mrgreen:
Electric Warrior
Big Muff (green russian)
JKowalski
VOX V809 Repeat Percussion
First etching - Toner on gloss paper, iron on. Filled in lightly toned areas with my etch resist pen - but, apparently, etch resist pen does not work on aluminum, which confounds me. So, it's a little grungier than I was going for, but I am fine with that!
For those who don't know, the effect is sort of like a tremolo/echo. The oscillator for the trem is pulse, and each pulse is shaped in the same way as a pick attack on a guitar. So if you leave a note ringing, instead of ringing, it makes it sound like you keep hitting the note, on every pulse of the oscillator. It's a really neat sound - Spacemen 3 used repeat percussion heavily. Slightly modded from schematic - it has the depth mod, but the pot used for it is 100K instead of 10K to give it more of a range. I also gave it a bit more gain so it can function as a boost pedal as well - it colors your tone a bit, in a nice way. LED shows speed when effect is engaged.
Needs a battery holder, I know. I tried making my pedal cleaner this time around, and it gave me ALOT of extra room! CB is attached to the switch.
GREEN FUZ
Looks great. I really like the distressed/corroded effect.
shadowmaster
I've built several stompboxes but the pictures were posted in other threads. I can't believe this is my first time posting here. Anyway, here is my latest baby.
It's a Phase90 with an added Leslie style ramp-up/down LFO by R.G. No LFO, either one of the LFO's or both LFO can be used. Below are some of the details.
Top row knobs:
1)Wet Level
2)Stock Phase 90 LFO Speed
3)Width
4)Feedback
Toggle Switches:
1)Stock Phase 90 LFO On/Off
2)Univibe Switch
3)Ramp-Up/Down LFO On/Off
Bottom row knobs. Basically the controls of the Ramp-Up/Down LFO.
1)Ramp Speed
2)Hi Speed
3)Lo Speed
Footswitches:
1)Ramp Up/Down
2)Bypass
hubble
shadowmaster...how do you get those nice looking trade cuts??
railhead
Quote from: m-theory on March 21, 2009, 03:49:25 AM
Where did you get that battery holder? The ones I bought from Mouser are too tall to fit into the B-size shells I use...
The French connection
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
shadowmaster
Quote from: The French connection on March 21, 2009, 10:55:42 PM
Quote from: hubble on March 21, 2009, 09:46:33 PM
With a drill bit i guess...
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/TUTORIALS/album21/STEP_THREE.jpg.html
Yup! I just used a drill bit although recently I just bought a stripboard cutter but haven't used it yet.
caress
svstee
Did you check out the battery holder at smallbear?
solderman
#8957
Quote from: JKowalski on March 21, 2009, 07:32:21 PM
Hi
Looks even better this way, hard to get something look authentically "reliced".
BTW have you a schematics and/or a layout for this effect it seems like a fun build in contrast to all distortion pedals. searched here but found zero.
EDIT:
Mr Google had the answer as so many times before i hope is this the schematics you used???
http://analogguru.an.ohost.de/001/schematics/Vox_RepeatPercussion.gif
What trannies/ FET did you use???
//Solderman
www.soldersound.com
JKowalski
#8958
There it is. It's a really neat sound - you really should try it out. It needs a unijunction transistor though - it lets you get that pick attack wave shape real easily. I got a handful of them (2N2646's) from ebay.
For the LED to pulse with the speed, I just buffered the oscillator's signal on the middle pin of the unijunction transistor with a LM741, and then controlled the led on/off with a rat bypass setup.
EDIT: I thought you would find it! I used a 2n3904 and a 2n2222 for the transistors, I forgot which ones I put where. And thats not a FET. It's a unijunction transistor - a unique type of semiconductor - it has two bases and one emitter. I used the same as listed, a 2n2646. I dont know if they still make them...? Might have to get NOS like I did.
EDIT 2: Yeah - on mouser, there's a replacement for the 2n2646 but they go for $6.00 apiece!! I got six of them or something on ebay for about 3 bucks.
If you want to try - I can take a pic of the oscillation signal at the base of the modulation transistor on my scope and you can try to replicate it with a different oscillator..?
solderman
#8959
Quote from: JKowalski on March 22, 2009, 02:57:07 AM
Tnx, Il try to hunt it down trough my "NOS source" or EBay. I'm not really sure I got the  LED pulsing setup do you mean from E> Pin 3 then take the Cathode on the LED to pin 6 and switch LED anode+ ROhm On/of on the stompswitch?? any Chan's of a schem??
//Solderman
EDIT: Found the 2n2646 for a OK price at Banzai http://www.banzaieffects.com/2N2646-pr-16504.html
EDIT: Think I found one who has taken this one Commercial and beaten me to put it in a 1590A box :o :o
http://www.catalinbread.com/Valcoder.html Time to get the old soldering iron going  ;D ;D
//Solderman
www.soldersound.com
