juse
Quote from: Focalized on April 15, 2009, 03:57:26 AM
Most recent Fuzzes and others. Have not posted any pics in this thread for some time.
Lots of cool work out there!
Tasty! Looks nice.
Güero
Quote from: flo on April 15, 2009, 06:49:52 PM
Quote from: Güero on April 15, 2009, 08:44:57 AM
This is my modded DOD FX91 Bass Overdrive. ...
That looks good!
Do you perhaps have a link to the schematics of that DOD FX91 bass overdrive?
EDIT: I found this:
http://www.sugardas.lt/~igoramps/article16/fx91.gif
Yes! this is the same sch that I used.
I just put a 27n in C24 position...more treble than the original.
The other mods regarding buffered bypass and a circuit to LED.
Curing the infection one bullet at a time.
panterica
Quote from: Güero on April 16, 2009, 09:23:51 AM
That looks good!
EDIT: I found this:
Nice! A couple of my favorite bassists use this pedal. What kind of op-amp and transistor did you use? How does it sound?
Güero
Quote from: panterica on April 16, 2009, 11:31:02 AM
That looks good!
EDIT: I found this:
I used the TL072, I think that other OPAMP sounds the same way.
It sounds great. The distortion sounds natural.
The BLEND control works fine and the sound come fat.
The unit have a lot of gain.
BAARON
Just a preview of the amp I'm building right now.  I know it's not a stompbox, but seeing as I got my start building stompboxes I figured I owed you folks a picture.
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
Andi
A quick gutshot...
MOSFET polarity protection, charge pump, 15v regulator, TS style clipping section, BM style tone control, trimpot to set the level going to the feedback control. It's the insides of the red pedal I posted a few days back.
GREEN FUZ
#9146
I bought these in the UK, though I`m sure you can find a local equivalent. For the measly sum of a quid - at Poundland, where else? - you get 2 of these fine stainless steel enclosures, one slightly smaller than the other. They are actually indian style food containers. Sort of a poor man`s Bixonic Expandora type enclosure, I like to think.
There`s loads of room inside, but be warned, the metal is an absolute pig to cut. I would recommend the use of a centre punch to get you started. Another recommendation is eye protection because when the drill digs in, little razor sharp shards of metal start flying. Ferric chloride doesn`t seem to make much of an impression either.
My favourite "feature" of all, is the convenient battery access.
svstee
Any noise problems with the plastic back?
GREEN FUZ
Nothing discernible, though it would be a simple matter to stick aluminium foil, or some of that aluminium tape, on the inside of the lid to enclose it completely .
Ripdivot
How did you do the emblum. It looks very cool!
GREEN FUZ
It`s made from a thin sheet of aluminium that I acquired from a kid`s craft toy called 'spirofoil'. You could probably get something similar at a craft shop. It`s very maleable and easy to work with. I first created a template in Photoshop and printed it out it on plain paper. Then by using some sort of tool - a pen or pencil would do - you go over the template pushing hard to create an impression. You can go back and forth working on alternate sides of the metal till you get the level of embossing you want. I screwed it up a bit so started stippling with a sharp object in an attempt to cover the mistakes. After that it was cut to shape and glued to the enclosure with a two part epoxy.
SonicVI
Quote from: GREEN FUZ on April 18, 2009, 02:37:51 PM
Very nice! And it keeps your circuitry nice and fresh! :)
Just finished this up on a dreary rainy day with nothing else to do. It's a Rangemaster, with CV7112 NPN tranny and blendable input cap.
deaconque
Quote from: SonicVI on April 18, 2009, 06:54:29 PM
Lovin' the knobs.  Looks good.
solderman
It most be a curry Fuzz then ;) ;)
very Nice. I like this kind of inventive thinking.
//Solderman
www.soldersound.com
owenjames
punkin
wow! That's just plain cool.
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
Insanekane
Folk Fuzz 3.5 Permille
Pretty nice sounding od/fuzz.
solderman
Quote from: Insanekane on April 19, 2009, 03:45:03 PM
Is that made from the schematics posted in the  Fuzz magazine a year or two ago?? I.v been looking for it. o you ave a link to it. ??
//Solderman
www.soldersound.com
juse
Mugshot
my recent builds:
a TOnebender MK2 using PNP germanium trannies and negative ground supply
volume pedal is in front, to control gain
this one's a Rat Distortion, PCB made by my good friend Lipton
this one's Tim Escobedo's Folkurban Octup (enclosure previously a mini pedal looper/isolator)
sorry for the crappy pics  :P
i am what i am, so are you.
