Galego
Quote from: Strategy on July 17, 2011, 10:19:03 PM
@ Galego - the C64 was already destroyed before it came to me...So I recycled all the pieces. Usable parts went to a friend who can use the parts for his Commodore64-rebuilding projects :icon_biggrin:
The shell was going to be just thrown away so I used it.
Well... at least it was a donor for other needing C64's. :)
~arph
Do you still have the audio IC? that is highly sought after.
ShortScaleMike
darron
#16863
Purple powder coat Klinger Custom Pedal with 3D texture and aluminium plate... MMMM (:
It's a MKIII
P.S>
where do you get the cool blue MKT's ShortScaleMike? (:
ShortScaleMike
Very nice, love the faceplate
I get my caps from a local English supplier bitsbox.co.uk
darron
Quote from: ShortScaleMike on July 18, 2011, 09:45:57 AM
thanks. (:
might check them out on my next order for caps... uk post isn't too much these days.
John Lyons
Something different for me (by me)
Basic Audio Pedals
www.basicaudio.net/
Govmnt_Lacky
Quote from: John Lyons on July 18, 2011, 01:02:21 PM
OK John... I'll be the noob  ::)
What is it? What does it do? Where is the porn?  :icon_biggrin:
^and me. :)..how do  you tighten those switch nuts tight without scratching the box finish?.... :icon_cool:
azrael
your server doesn't allow hotlinking anymore? :(
http://www.basicaudio.net/Squarewave-orange.jpg
so. wat circuit is it? I recently made a vero layout for Escobedo's Square Wave Shaper, haven't verified it yet. :D
LaceSensor
My latest effort. Its an OLC chunky cheese on Perf next to a Doug Hammond Tone Source on Vero.
kvb
#16871
Here are a few new builds.
GGG BrassMaster - Check my gallery, This is the first pedal I've painted.
Drawing on paper adhered with clear-coat.
I tapered the enclosure.
No nonsense Harmonic Percolator. Settings permanently at max. No LED
Foxx Tone Machine. The bottom was a lucky find in the scrap-yard.
The LED is bi-color to indicate when the "up" is on.
Mac Walker
Big muff, Green Russian version  ;D
I like to drill a through hole on the stripboard wherever there is a break, makes it easier to assemble...
LaceSensor
That muff looks saweet
John Lyons
Let's see...
Univox squarewave, highly modified. (kudos to Mark Hammer for some tips.  ;))
Different build, same guts as the orange one.
^and me. how do  you tighten those switch nuts tight without scratching the box finish?....
Very carefuully.  :D
Sounds like this:
Basic Audio Pedals
www.basicaudio.net/
Mugshot
an overdrive build:
fixed some bugs in the layout (got an electrolytic in backwards, d'oh!) hence the heat tubing. in hindsight, i should've used "normal" input jacks, fancy jacks only make it harder for me to come up with a cleaner build, and makes it more difficult to ground the box (see "cheat" :lol:). fixed the box grounding problem by drilling a hole and using a screw bolted to the body to connect grounds.  ;D
i am what i am, so are you.
Govmnt_Lacky
Keppy
LaceSensor
Quote from: John Lyons on July 18, 2011, 10:54:06 PM
Let's see...
Very carefuully.  :D
Sounds like this:
sounds terrific
aflynt
Fried Chicken Fuzz / Range Boost
In an attempt to save space on my pedalboard I built a new version of my fuzz/boost combo pedal into a 1590NS oriented so that it's shorter width-wise and longer height-wise. I used Tonepad Fuzz Face and Rangemaster boards and built both circuits negative ground so they would work with the AMZ relay switch boards. I must say that a negative ground fuzz face is quite the PITA.  :) Even with the BFC it's quite noisy with the volume rolled off. The layout of the boards also isn't really conducive to neat wiring for what I'm trying to accomplish here either. I'm considering gutting it again and building the circuits positive ground on different boards and with a charge pump so that I can still use the AMZ switching.
-Aaron
