cloudscapes
wow! love the line art ear!
{DIY blog}
{www.dronecloud.org}
gulnare69
#19381
First post!! Hi all.
I'm not a tidy boy, but if it works, I care not.
Frankenstrat with Uglyface and lfo (it now has some LEDs for bypass and lfo rate):
Spaghetti:
Tweakage:
Bottom to top: Harmonic Percolator, Tech 21 XXL and a Crunchbox with fx loop:
Dr Boogie in a a happy flying dog tin (white washer on the outside purely to prevent the tin from buckling):
The cat will tell you where the power goes:
artifus
good work! when i eventually get around to taking some pics of my builds they will come with the tag line 'no guts - too gory'.
so long as it works i am happy.  :P
gulnare69
#19383
They're getting tidier, the guitar had a lot of messing around and i kept everything long so i could move things around in the cavity.
The Dr Boogie was my first perfboard project, I like it! Worked first time round, and the board looks so much nicer than with copper strips everywhere.
John Lyons
Basic Audio Pedals
www.basicaudio.net/
Earthscum
Hey John... you should check out the scissor cut copper clad at Electronic Goldmine: http://www.goldmine-elec-products.com/products.asp?dept=1034
I did a plate on a Rat for a friend. I etched away all but the boxes and lettering, tinned them, and did an etch of a nasty rat on the backside. If you can keep the stuff from staining, it's so thin, very translucent. The copper from the backside shows through as a brownish figure. I did some tests before hand painting the backside with some really fantastic results. Yellow worked great, kind of a vintage look of sorts, and contrasts the copper well. It's thin enough, though, that you can pull up edges, so you'd want to secure it with some double sided tape. I got pictures of it before I sent it off, but they are on the Sony and I can't find the cable.
Colonel Angus
I love the marbleized PCB surface! Can you talk about your grounding technique? It seems like the output lugs only have one wire attached.
Quote from: frequencycentral on June 16, 2012, 12:59:15 PM
Why should you not have 90o angles? Do the electrons bunch up in the corners?
nice knobs John
mth5044
Quote from: Colonel Angus on May 14, 2012, 08:27:59 AM
The ground lug of the input and jack is touching the enclosure (by way of how it is mounted through the hole), which grounds the enclosure and anything touching it, including the output jack.
Ettore_M
Quote from: nicofx on May 10, 2012, 03:19:36 PM
Magnus Modulus
Great builds, Nicklas! Really nice and tidy! Well done!  ;)
What type (size) of enclosure did you use for the Magnus Modulus?
The Tone God
Fun little product we just released. The Acoustic Pickup Adapter which is a mounting ring that allows you to mount a standard electric guitar pickup in an acoustic guitar without having to modify the guitar.
Andrew
puretube
Quote from: The Tone God on May 14, 2012, 04:26:50 PM
Andrew
RESPECT !
:icon_cool:
tasos
+1
Can this be bought somewhere?
puretube
Quote from: tasos on May 14, 2012, 04:47:55 PM
+1
I`d check out this link  :icon_wink:,
and hope this thread not going to be locked...
[Disclaimer:] poster is not in any way affiliated with aboveto linked site/product...
roseblood11
Andrew
Please get a european/german distributor for that thing quick! Maybe thomann.de or musik-produktiv.de...
mattthegamer463
TTG,
Where can I mail the blank check to?
~arph
Erm. don't you have to mod the guitar for the tone/volume control, plus jack socket  ???
midwayfair
Quote from: ~arph on May 15, 2012, 08:31:42 AM
You can mount the controls inside a guitar pretty easily, and it wouldn't be too hard to wire a trimmer into that plastic holder. Otherwise, just wire the pickup to the jack. yes, you do need to install a jack in an acoustic guitar ... to use any mounted pickup.
These are clearly designed to add an electric guitar pickup to an acoustic. It's 1935 all over again!
Jdansti
The jack goes where the end pin is. I've got a couple of acoustic electrics and you wouldn't know they were electric unless you look for the hole in the jack. My Martin has a trim pot installed just inside the sound hole near the low E string. It's easy to adjust. Here's a video of the jack installation:
arma61
you can easily build a small box like this, it's the wellknown SWTC and it goes direcly on the output jack.
http://www.diystompboxes.com/smfforum/index.php?topic=36392.msg835484#msg835484
Ciao
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
