Nikolay
^Thanks!
Your multi effect looks so massive and heavy!
BTW, for effect like this you don't need so thicker sheet metal. Typical 1mm sheet is enough.
Niki
Thomeeque
#19601
Quote from: sugonidamaso on June 10, 2012, 09:11:27 AM
Great Job T! Always an admirer of your work!
Thanks S :)
May I ask how did you do the wiring? Please? Thank you!
OK, no time now but I'll post some diagram later.
Quote from: Nikolay on June 10, 2012, 09:12:20 AM
Thanks, yep, it's 2.5mm steel and I know it's overkill (total weight 1.2kg :icon_rolleyes:), but I don't own sheet bender and the guy I usually go to did not have time for me so I have just bought piece of the thinnest U profile with propper dimensions local store sells. At least I did not have to bother with any strength considerations :D
nordicskiah
Quote from: cloudscapes on June 10, 2012, 07:23:09 AM
Quote from: nordicskiah on June 09, 2012, 02:55:42 PM
P.S. Decided to not label volume and gain after trying out my fancy handwriting on paper ^_^
Just noticed the nice knobs, too.  :icon_biggrin: Boss middle? Did you get the problem where the epoxy oozes down the side slit?
Ha, yeah. It kept dripping down and I had no idea where it was coming from. I just kept pushing the knobs on a piece of cardboard with a scrap piece of wire from a resistor or something. As long as I moved it every 20 minutes for the first couple hours it wasn't going to stick. Eventually I took a floor tile, wrapped it in tinfoil and put the knobs on top of it and in the oven. They un-stuck from it pretty well.
Thanks again for all your posts Cloudscapes!
sugonidamaso
Thanks S :)
Thank you T. ;D
" The greatest inspiration is often born out of desperation--so be DESPERATE! "
ok not finished...but... ::)
2 etches for small clone chorus,  the  one on the left is for a old friend who collects war militaria stuff, he'll love this....its his 50th birthday present. :icon_cool:
it will have blue on/off led and a standard 3mm blue pulse led in the centre of the iron cross...  :icon_cool:
the one on the right is the 'baphomet'  for a friend who is an angel witch fan.  old school.....
same blue on/off led...and standard blue in the lap of the baphomet...(baphead )
Jdansti
Quote from: Thomeeque on June 10, 2012, 09:02:51 AM
Impressive as always, Niki! :)
After long time I did something stompy again, relatively quick and dirty custom multi-fx for my new bandmate with stuff he currently needs (and cannot afford to buy any soon) ..so even my own EM3207 has got finally boxed :D
Little more photos here..
It will get powder-coated later yet, and some better sticker, but we need to use it already now.
Cheers, T.
Very well done!  Where did you get the enclosure?
Globe Town Free Arts Lab
Rangemaster + Green Russian Big Muff
Gristleizer
EchoBase
motvej
Echo base
title is smth like "F*KING GROOVY!"
Thomeeque
I have updated the original post.
Quote from: Jdansti on June 10, 2012, 12:42:46 PM
Thanks! I have built it :) Top is 320mm of the steel "open U" profile 70x30x2.5, bottom is 1mm steel sheet with bended sides.
T.
darron
Quote from: motvej on June 11, 2012, 07:40:09 AM
Echo base
winner!
Ofek Deitch
How did you make those cool labels??
midwayfair
Echo base
ochen xorosho! :)
artifus
@ofek - search the forum for slade's etching tutorials
motvej
gulnare
Weekend work:
Harmonic Percolator
Gutz
Weekend stupidity:
Clari(not) w/fuzz lift and feedback knob. I just stuck a 1M pot between the delay out and the in of the PT2399, much chance this will fry the IC?
It seems to work pretty well, nice extended delay tails at lower settings and at max it oscillates then craps out. Turning it down again seems to reset.
Gory
I also had some luck making fader knobs with Fimo, but that pedalboard is buried under guitar cases and it's too hard right now.
Jdansti
Quote from: Thomeeque on June 11, 2012, 07:43:34 AM
T.
Thanks for the information on the enclosure! That is a great idea as you can make it any length.
Thanks also for posting the wiring schematic.  I notice that the resistors and capacitors on the vcc vary for the different effects.  I am curious as to how you decided on the values for each effect.
Al Heeley
Last delay pedal build off Tonepad's Rebote 2.5 pcb
bean
Love this thing.
Slade
#19618
Quote from: bean on June 11, 2012, 05:23:10 PM
Love this thing.
+1
My personal favourite :icon_biggrin:
That's a really nice plate. The box color fits perfectly.
Jdansti
Love this thing.
Very nice!  You should photograph that on on a grill or maybe sitting on a large bun!
