duh! I forget to look in profiles  :icon_redface:
John Lyons
Basic Audio Pedals
www.basicaudio.net/
gulnare
Crunchbox with various clipping/opamp selection and AB loop:
No guts, it's messy and I forgot to take a pic before the bottom went on.
Govmnt_Lacky
I really like the faded look on those enclosures  :icon_cool:
gulnare69
That's what happens when you use coloured Envirotex on an unlevel surface :P
nordicskiah
Quote from: gulnare69 on July 25, 2012, 10:02:59 PM
Coloured Envirotex?
This requires a tutorial!
Pyr0
Ahhh, a happy accident. It's great when they turn out, but can be frustrating to reproduce. Nice.
tuckster
Quote from: gulnare on July 25, 2012, 11:34:45 AM
Veeeery nice enclosure. How did you do that paint job?
RonaldB
I have made a CE-2 clone on the Tonepad layout.
Since i had a set of unused MN3207 and MN3102 I put them in here.
I made some changes for powering the MN3207 and worked great.
I also like the looks of Toneczar pedals so that was my inspiration for this one.
Other mods I did was:
- Wet level pot
- Vibrato switch
- Intensatie switch (ads a 100pf in parrallel with the 47pf cap add the MN3102)
- Deep switch (changes the 0.1uf in the LFO section to a 0.068uf)
- expression pedal input for the Speed pot, (haven't tried this one out still)
Here are the results. (The guts are a little messy, a lot of wiring)
skullservant
Just installed the hardware and mocked up the knobs for this fuzz I'm working on for a friend. It's a Maestro FZ-1 into a Shin Ei FY2, both with power starve, blend control, and stomp switches for each to go from 100% wet to whatever the blend is set to. It was etched by the almighty DAN.
Also put this together last night. I noticed that Mascis once had a board that was just a Fuzz Factory, AD-9, Lofi Loop Junkie and a Sans Amp. So instead of just making another old Big Muff, I figured why not make something I hadn't before?? Mascis' Fuzz Factory was this very same purple!
@RonaldB
First of all, you have a great 80s rapper/DJ name, second where did you get that enclosure? Is it just the photography or is it an extra-deep 125-B?
Govmnt_Lacky
Quote from: garcho on July 26, 2012, 10:58:59 AM
...second where did you get that enclosure? Is it just the photography or is it an extra-deep 125-B?
I believe that is the extra-deep 1590BBS  ;D
http://www.hammondmfg.com/pdf/1590BBS.pdf
RonaldB
Quote from: Govmnt_Lacky on July 26, 2012, 11:36:47 AM
@RonaldB
Well it's actualy an 1590C.
gulnare
Quote from: nordicskiah on July 25, 2012, 10:34:52 PM
Coloured Envirotex?
Naw, just dump some PSTF pigment in and mix good. I got it from here:
http://www.amcsupplies.com.au/index.php?main_page=index&cPath=18_269
Quote from: tuckster on July 26, 2012, 07:23:05 AM
See above, It was meant to be smoke grey over rustguard white/cream, but it came out a bit green. I like it anyway.
mth5044
Now you know you're going to have to go on about that quadcore delay :)
cloudscapes
four PT's?  :o
what's the feedback path like?
{DIY blog}
{www.dronecloud.org}
Govmnt_Lacky
#19877
Always stunning Rick!!!!  :o
EDIT: Just noticed.... those are SOOOOOOO 2011  ::) At least, according to the signature on the pedals!
cloudscapes
TBH Rick, those would look PERFECT with metal washers for the stomps  ;)
{DIY blog}
Quote from: Govmnt_Lacky on July 27, 2012, 06:59:59 PM
Long delay...
