Govmnt_Lacky
Quote from: pickdropper on January 29, 2013, 09:08:49 AM
This is my Swiss Army Pedal
Absolutely AMAZING!!!  :o  :o  :icon_eek:
^ yeah pukka!!!.. 8)
tca
My new headphone amp using a TL431.
gcme93
Pickdropper, that thing is awesome and pretty close to what im hoping to build. What size enclosure is it? (im looking at having four smaller circuits so it won't need scaling up by too much)
Piss poor playing is why i make pedals.
thelonious
Thanks, guys!
Quote from: garcho on January 28, 2013, 11:33:21 PM
damn, dude. can i clean your apartment or something?
Man, it seriously needs it after this pedal. It ate all my free time for a while... not much cleaning was happening last week.
Quote from: deadastronaut on January 29, 2013, 03:45:46 AM
@thelonius:  cool, i tried fibre optics on a delay too, but the fibres kept breaking at the point of contact,  i think it was the superglue that affected/rotted the fibres.
Yep, super glue messed up my first attempt, too. Even hot glue can be sketchy because of the heat involved, but if you're fast, precise, and don't use too much, it works. A dual-temperature gun set on the low setting would probably be better than the $5 cheapy I bought at home depot. From what I've heard, the best choice is actually either two-part epoxy or the special glue made for fiber. But hot glue is so fast and cheap...
Also: You just can't bake at all when you're using fiber or hot glue. I tried lots of temperatures and methods, and they all destroyed something. Even temperatures low enough that they don't melt the glue or fiber still make the fiber brittle and prone to breakage. Patience in paint drying is the only way to go, and as you can see from the clear coat halos around my washers, I was not quite patient enough. :D It's possible that very careful application of a heat gun from outside might work, though, especially if you had a small fan ventilating the underside of the pedal. If anyone has any other ideas... please share.
^ aha so superglue was the culprit...confirmed.  cheers man. i'll have another crack at it one day.
i still have plenty of fibres left over... 8)
pickdropper
Quote from: gcme93 on January 29, 2013, 10:16:51 AM
That is just a stock 1590bb.  Nothing fancy.
And thanks for the kind words, guys.  I've seen the quality of the stuff you build, so I take it as high praise.
Govmnt_Lacky
@pickdropper
I assume that your Swiss Army pedal is a laser etch over powder coat. How was it done? Engraving shop?
pickdropper
Quote from: Govmnt_Lacky on January 29, 2013, 11:49:38 AM
@pickdropper
Yeah, this was indeed laser etched.  I did it at work, but I am looking into trophy shops as I don't want to push my luck by using the one at work too often.
SmoothAction
Here's a lovepedal superlead (tagboardeffects, awesome layout) for a buddy who wanted one. Sounds pretty damn good! Lots of gain, switch goes from zener to LED clipping, the zener diode sounds really good. Hadn't used one for clipping before. No gutshot this time guys, went to him as soon as it was finished.
Thanks for looking
"Never heard a man speak like this man before, never heard a man speak like this man before. All the days of my life ever since I've been born, never heard a man speak like this man before."
nordine
#21210
Who here likes llamas?
Do you even llama? No? You should  ;D
ca cat
Fuzz factory with possibility to control stab with external pedal. The name was not my idea :icon_mrgreen:
Simple mini footswitches
The half stack - great, dynamic plexi like drive:
Modified wooly mamoth
Jamin' with JaM IT FX - www.jamitfx.com
midwayfair
Quote from: nordine on January 30, 2013, 08:40:06 PM
I like Llamas. :)
Nice paint job!
@ca cat: Really like the Wooly Mammoth name and graphic.
bean
Not very creative graphics on my part, but I needed to get these done. First is a 5/6 stage OTA phaser and the second is a dual delay.
electrosonic
#21214
Another Rat pedal - changed the "filter" control to a "tone control", made the cap bigger in the tone control for more range and used a leaky AC128 for the buffer.
(the idea is from the AMZ site http://www.muzique.com/news/leaky-ac128-buffer-redux/)
I made the boards in Eagle and had them fabbed via OHS Park.
Mictester's (from that other forum) relay switching circuit on the small board.
The satan skull graphic was supplied by my band mate (and now pedal owner), used press n peel and electroetched with copper sulfate.
Andrew.
Nicely done Andrew!
I've got some of those relays on the way to build mictester's bypass circuit, how do you like it?
electrosonic
#21216
I have no popping at all with this set up. I was careful with my ground layouts,  the LED and relay have their own ground path and filter caps. I use a SPST switch (not momentary) which keeps it simple (no logic used). I like to have the jacks coming off the top side of the box so the pedals can be stacked side by side easily, but that makes for messy internal wiring (at least by my skill level). The relay solves that problem. I also used a 2 pin header jacks for the switch (and battery clip - not installed) so they can be replaced easily.
Andrew.
Edit: just got back from band practice. The relay switching is not silent, with my guitar volume rolled off and the pedal plugged into a fairly loud tube amp, I can hear a slight pop when the pedal is turned on. Not loud enough to matter, but it is not silent like some electronic switching or relay with a mute.
EATyourGuitar
this ^ wow nice PCB's Andrew! I bet that really reduces your build time too.
this is the paralell universe I built to test the new PCB. this project has been approved by Colin @ Experimentalists Anonymous
WWW.EATYOURGUITAR.COM <---- MY DIY STUFF
Nikolay
Here is a small custom A-B switcher
kaycee
Clone of the old Maestro Full Range Booster. From Analogguru's schematic, built on vero.
