moosapotamus
Quote from: John Lyons on July 15, 2013, 12:20:58 AM
Dig that paint job! (gives me some ideas ;) ) Very nice, John!
~ Charlie
moosapotamus.net
2lane
Quote from: jimilee on July 10, 2013, 12:55:06 PM
Quote from: 2lane on July 10, 2013, 06:12:09 AM
;D
Wait..how are you gonna post something like this with no explanation? This is fantastic!
sorry about my english
it's a Sansamp GT2 and Deep Blue Delay with Modulation. :icon_biggrin:
g.
Quote from: John Lyons on June 17, 2013, 04:18:58 PM
Feeling a little fuzzy 'n blue here.
i'm late to the party
but this one is beautiful John !
rousejeremy
That's not late to the party, this is late to the party.
Quote from: Hal on August 23, 2005, 01:58:47 PM
post your pictures!
Left to right, Easyvibe, Easyface, Green Ringer, Rangemaster (pot is screwdriver adjust on right side.  I know the input and output are backwards....it was my first time doing PCB mount, and doing a sharpie layout)
www.jeremyrouse.weebly.com
midwayfair
Dude, you need to remove the quote coding if you're going to repost #1 at the top of a page.
John Lyons
Thanks guys!
maybe silly or minor question, but what's the thought behind using the
bottom lugs of the 3PDT further away from the boards/jacks rather than flipping it?
No real reason. I just memorized that lug pattern/convention and I use it every time.
None of the wires are crossed generally and I have a procedure which I follow each time.
This is the GGG layout and since I learned with that it carried it over and it's second nature
to me now.
Basic Audio Pedals
www.basicaudio.net/
rousejeremy
Quote from: midwayfair on July 15, 2013, 05:54:26 PM
I really should have, that would have confused everyone.
jimilee
Quote from: 2lane on July 15, 2013, 01:31:13 PM
;D
I kind of meant the overdrive pedal, it gots a lot of switches on it.
THOMMO
I finished this one this afternoon. I f%#$ked up the positioning of the LED eyes, though  :icon_mad: I tried to drill them from the inside after the top was finished and must've messed up the measurements when I transferred them to the inside. Oh well, you win some, you lose some! You all should be able to guess the circuit from the graphic(I hope)  :)
Cheers Thommo.
May The Twang Be With You
Quote from: midwayfair on July 15, 2013, 09:25:18 AM
Start a debug thread and I'll help you out. :)
Thanks Jon - will do.  Just want to go over my homebrew Vero layout first.  I'm hoping it's something obvious and stooopid.  Otherwise, a debug thread is on its way!
Edit: found a bug in my Vero layout - missing track cut!   :icon_rolleyes:   Will fix when I get a chance and report back...
Govmnt_Lacky
Quote from: THOMMO on July 16, 2013, 03:18:35 AM
Thommo,
You could always open up the holes just a bit and try 5mm LEDs  :icon_cool:
Might make it a little better  ;)
Great build by the way!!
haveyouseenhim
Quote from: Govmnt_Lacky on July 16, 2013, 09:02:50 AM
Thommo,
Nah, go Robo Cop style and put a row of LEDs  :icon_mrgreen:
Govmnt_Lacky
Quote from: jimilee on July 15, 2013, 11:40:29 PM
He did say what it was Jimi. Its a clone of the Sansamp GT2 amp modeler.  ;D
Valoosj
Quote from: frequencycentral
Quote from: Scruffie
jimilee
Quote from: Govmnt_Lacky on July 16, 2013, 09:33:25 AM
i guess it would then be silly to ask about all the cool switches and what they do then.
fretzburner
pc screen shot
capture
Still studying the label thing
Seven64
Muff, no gutshot sry
has clean blend and diode lift toggle
Devi clone on her pcb
THOMMO
Thommo,
Cheers, that's not a bad idea Govmnt_Lacky. I'm not sure how I feel about changing/fixing it atm. I've got some metal LED bezels for 3mm LEDs here but they might make it look a bit weird! Not sure!
@Mike, after seeing your suggestion I'm thinking Crylon style!
Btw if no one got it, this bad-boy is a Distortus Maximus. Awesome pedal!!!
Thommo.
darron
#22358
the test circuit i built with crocodile clips for auditing transistors.
AKA Robot Dr Zoidberg
~arph
