Tycobrahe Octavia TOO LOUD!
Started by Delay, August 24, 2005, 07:49:09 PM
Delay
Some time ago, I build a Tycobrahe Octavia clone..it works perfectly, but it's sound best to me when both VOLUME (=output level) and BOOST (=gain/octave) knobs are at full level.
There's some way to reduce the output of this pedal?
I've changed the Volume pot from 500k to 250k, but there wasn't a big difference..
Filippo
smccusker
shouldnt you have replaced the pot for a higher value?
I had this exact problem, because i used higher gain transistors in mine, so I put a resistor between the wiper lug of the volume pot and output capacitor.
Guitar -> Amp
Pedal love
Which transistors did you use?  mpsa18+2x2N3906?pl
smccusker
2X mpsa18 and a 2n3906
Id sourced the parts from the pos ground circuit, but built from the neg ground one at GGG.
so theres a whole lot more gain there than was supposed to be.
Its a shame though, the resistor (4m7, mind you) got it down to a useable level, but im sure it doesnt osund as good.
someone suggested putting a cap in series with the resistor, maybe to compensate for some of the bass loss caused by the resistence.
Any thoughts?
Guitar -> Amp
Pedal love
And ah, which transistors did you use delay?pl
smccusker
Guitar -> Amp
Pedal love
Its ok...  :D  I was just interested in which transistors, but I really don't have any more comments, so I'll stand down now and leave delay, in the capable hands of smccusker. :D pl
 A cap across the signal path lugs of the pot.
 Figureing out the small value is the tricky part.
 A voltage divider is another option, 2x 470k seriesed from SP to ground, output pot input lug from the 470k junction, adjust as necessary.
 I have n/p with lack of highs with the Tycho, I don't know what difference using 100k does, probably not much.
 Volume pot voicing, easily overlooked.
smccusker
I'll have to dust the old tychobrahe off and try some of those, thanks!
Guitar -> Amp
Delay
Quote from: Pedal loveWhich transistors did you use?  mpsa18+2x2N3906?pl
I've build the Neoctavia project of tonepad.com, it doesn't use any transistor just two Ge diodes (1n34) and an IC (RC4558P)..what IC should I use to reduce the output?
Filippo.
