Cheap pressure switches (from washing machines)
Started by brett, August 30, 2005, 08:07:18 PM
brett
Hi.
The latest issue of Silicon Chip magazine is out and contains info on pressure sensors that might lead to further research concerning their use in stompboxes:
Older washing machines and dishwashers use mechanical pressure switches to detect the water level inside the tub. A hose is connected from the base of the tub to the pressure switch, which measures the air pressure being applied by the column of water.
The pressure at the base of a column of water 27.69 inches high is 1psi, or to put it another way, 10.2cm of water exerts a pressure of 1kPa (kilopascals). So, as you can imagine, a switch that’s designed to detect when the water level in a washing machine has reached (say) a depth of 15 inches must be capable of accurately measuring pressures of just 0.5 psi (~3.5 kPa)!
Washing machine and dishwasher pressure switches can be easily scrounged for nothing - you'll find a pressure switch inside nearly every one of these appliances when they're discarded. They are extremely sensitive and their trip points are externally adjustable.In other words, the pressure switches in washing machines are amongst the most sensitive that you can buy. Well, you don’t really have to buy them â€" these switches can be scrounged for literally nothing wherever washing machines are being discarded.
Washing machine pressure switches have three main characteristics:
(1) Very high sensitivity;
(2) A "snap" action, to ensure sharp, decisive switching â€" they’re either on or off; and
(3) Excellent power handling.
Thanks to Silicon Chip magazine.
cheers
Brett Robinson
nelson
My project site
Winner of Mar 2009 FX-X
brett
Dunno.  But I might go home from work via the rubbish dump (garbage tip?) this arvo and see what's available.
Brett Robinson
Hal
bwanasonic
Just be aware that this might draw attention from law-enforcement in certain environments. Lets just say that DIY pedal makers aren't the only parties interested in the properties of washing machine parts. Carrying them around in a knapsack is probably a bad idea as well.
Kerry M
gez
Executed Terrorist Pleaded "I was only doing it for my Wah Pedal!!"
