DIY FX loop for Behringer combo?
Started by blake, September 07, 2005, 04:29:51 AM
blake
Hola!
I just got myself a Behringer GM108 combo. It's a 15W, 1x8" nice little box featuring Behringer's analog modelling, which is also used in ther Tech21 clone pedal (GDI21). This is really a great combo with great sounds and lots of possibilities. Splendid sound and good reaction to an overdrive pedal up-front. Amazing bang-for-buck 8)
However there is no built-in reverb, and no FX loop so you basically cannot use post-FX's like modulation/delay/reverb.
Questions:
1)
Any of you have an estimate of the possibilities for opening up the amp (which I highly suspect to be an SMD build), and inserting an FX loop? Is it difficult to do this (for a newbie)?
2)
Any suggestion how identify where to "inject" the FX loop circuit on the print?
3)
Any good FX loop circuit diagrams/layouts?
Thanks  :D
blake
Just got this idea (will try out tonight when I'm back from work):
As the amp has both headphone-out and CD-in connections I might be able to insert my post-FX's there... The mix is probably 50%, but anyway... Worth a try  :D
Penguin
i have one of the V-ampire amps they make and was quite relieved to realize that there are some very familiar things in there and not everything is smd however over 50% of it is.
mine uses lm3886 chips for the power section. or well it did till i decided to gut the whole thing and put in two el34's in there with a tube preamp as well.
one thing i hated about the behringer is they use this god awful heavy transformer.  and i measured and remeasured the thing and found two smaller transformers with the same or slightly better votlage/amperage ratings and they were sooooooooooo much lighter.  so before i started gutting this thing i lost 15 lbs of weight by just changin out the the transformer.
In a corner of the churchyard, Where the myrtle boughs entwine, Grow the roses in their poses, Fertilized by Clementine.
