Sparkle Boost?
Started by Frostbite Slim, September 07, 2005, 10:36:42 AM
Frostbite Slim
Where can I find a schematic or PCB for this pedal? I'd like to build a good "clean boost" pedal and this one was mentioned...are there better ones?
I couldn't find a website for Dragonfly Fx's. Could someone steer me in the right direction?
TIA
bigjonny
Oops.  Double post.  See below.
bigjonny
Andy has asked that we not post any schems, but has provided a Veroboard layout...
http://aronnelson.com/gallery/album18/SPARKLE_BOOST_LAYOUT
mojotron
You can use JD's GGG GEB layout - which is used for the AMZ MOSFET boost as well as the Rangemaster. It's at http://www.generalguitargadgets.com/diagrams/geb_pcb.gif
From the vero layout you can workout the connections. The GEB is not a perfect fit, you will need to bend the legs of the FET to get the DSG to match the CEB, but the rest is straight forward. What I ended up with was just a good as any other layout.
Dragonfly
Quote from: bigjonnyAndy has asked that we not post any schems, but has provided a Veroboard layout...
thanks for the consideration Jonny !
that being said, i "have" posted the Sparkle Boost schematic in the layouts gallery "Dragonfly" folder :)
rock on !
andy
col
Build one, they are great! It is also very loud at full volume. When I built mine I had forgotten to connect the earth lead on my test rig and left it switched on with the headphones on while I re-connected it. I nearly blew my eardrums out.
Col
Dragonfly
Quote from: colBuild one, they are great! It is also very loud at full volume.  I nearly blew my eardrums out.
:twisted:
