Tranny Pinouts...
Started by CrazyMisfit, September 07, 2005, 04:12:37 PM
CrazyMisfit
Is there anyway to test the pinouts for 2N5306 tranistors, or any tranistors for that matter?  I am so confused as there seems to be two datasheets (Fairchild) that are avaliable for the 2N5306, so if there is a way to test which pin is what  that would be great!
I am building the Scrambler by the way...
Thanks.
Seljer
scroll down about 1/10 of this page for how to check out transistors
http://www.faqs.org/docs/electric/Semi/SEMI_4.html
Basically a transistor is 2 diodes back to back and you can figure out in what way things go with the diode test function of a multimeter
CrazyMisfit
Awesome, that helps alot!  Thanks for your help!
