Fender amp problems
Started by Vincent Volta, September 08, 2005, 12:38:22 PM
Vincent Volta
Hi all,
Lately Ive been having trouble with a Fender amp. Its a Princeton 65 with reverb, solid state. Its a cheap Mexican model, 1x12 combo and the 65 I guess means the RMS power - no specs handy.
When you drive the amp hard enough to be heard over a drum kit, the signal goes completely off and all you hear is a loud 50hz hum... a tough hit brings the signal back but not for long since another loud chord will spoil it again.
This has been happening for a year or so now, intermitently, it just got worse lately. My bassist is into electronics too and he suggested that the power supply filter caps might be the culprits- I peeped inside myself one day and noticed these are relatively small, 2200uf instead of 4700 or so.
I did notice that everything else looked fine and dead on, and the pwr amp is driven by two transistors in a wide plastic case. Had no time to check these devices or even write the numbers!
As for now I will change the filters- in a few hours when I finish work- but I wanted to share this here to see if someone has any clues. We are pretty much left on our own when we cover the subject of amp servicing here but I know for sure some of you know better than me! Thanx a lot for your patience and help.
P.D. Why are Fender solid state amps so crappy? Havent found a decently working one in ten years or more....
May the yoghurt be with you.
cd
Post your problem here, not in Stompbox forum, you'll get a better response:
www.ampage.org
Paul Marossy
It almost sounds like the transistors are going into cutoff mode or something...
Ripper
If a strong hit brings it back for a bit, you probably have a ground problem.   I just finished fixing a deluxe 90 with a similar problem.  It was a couple of solder joints that had gone cold and developed a "crack".  The humming is usually a good sign for a ground to.  Try resoldering any connection that looks cold and see if that fixes it.
ninoman123
How did this get back to the top of the board? Says the last post was in March and now its at the top...weird...
Edit: Just checked out the date on my post....says Feb!! Thats weird....
Double edit: Woah all the dates are off...never noticed it before!!!!! Ahhhh Im freaking out!
JimRayden
Lol, yea I've been mixing up the posting dates and the member joining dates too.
Jimbo
