The Juggler - what input impedance?
Started by bassmeister, September 11, 2005, 05:10:59 PM
bassmeister
I'd like to shed some light on the possible impact on input impedance when using The Juggler effects order reverser, as described in an article by R.G Keen http://www.geofex.com/Article_Folders/juggler/juggler.htm. I'm referring to the CMOS switch solution at the bottom of the article.
Do the biasing resistors affect the input impedance?
I was thinking that for an AC signal, they would be in parallell with the input impedance of the effects and thereby lowering the overall input impedance. Am I thinking right there?
bioroids
Yes, the biasing resistors are in parallel with the input impedance of the effects. You're right
Luck
Miguel
Eramos tan pobres!
