OT: simple, good sounding DIY mic preamp project needed
Started by AmpliFuzz, September 25, 2005, 09:19:39 PM
AmpliFuzz
I'm about to buy a M-Audio soundcard with 8 line inputs, two of which equipped with mic preamps. I need 6 other preamps to track drums, etc. I'm looking to build something and I'd like to keep it as simple as possible: no transformers, no phantom power and maybe no high-pass filter either, just XLR input with gain to line out. Any recommended schems/projects?
Thanks,
AF
PS: what about the power supply?
bioroids
Check out the AMZ Mosfet Booster. It works good for this, but has no XLR input :(
The schem is over at www.muzique.com
Luck!
Miguel
Eramos tan pobres!
littlegreiger
Check out here. There's two mic preamps that seem pretty easy.
cd
http://www.nomad.ee/micros/preamp1.html
Leave out the phantom power if you don't need it.  Easy to build using a single dual opamp for each input.
12afael
look at www.groupdiy.org
the green preamp is a good option.
I build the paia tube preamp and work great.
I f you want some more simple you can find some schematic with a ina103 , ssm2019 , ina217 as input amp and drv134 or ssm2142 as balanced driver.
on the page of rane (www.rane.com) they have schematic of their equipment. ther is a preamp too.
davebungo
you could also try the forum on www.prodigy-pro.com - it's more or less all they talk about.
